I just installed the 4.2 update on my rooted Nexus 7, but I accidentally overwrote the build.prop with the 4.1.2 build.prop.
Can someone please post the 4.2 build.prop so I don't have to factory reset? I can't find it anywhere.
Thanks!
Printable View
Thanks!
I could this evening if you can wait.Quote:
Originally Posted by ledsock [Only registered and activated users can see links. Click Here To Register...]
I believe you can find it within the factory image if you unzip and browse around it.. Link to download the image is in my factory restore guide.
Thanks! It would be much appreciated! I was going to try the guide to fish it out of the system.img file, but my linux box is out of order and I can't get Ubuntu to play nice with Windows on my laptop.
I managed to get Ubuntu running on my laptop. I was able to get the build.prop out of the system.img file, but unfortunately it didn't fix my problem. I attached it here in case anyone else needs it.
Oh.. sorry to hear. You able to get up and running at least? Either via a factory reset or factory image restore?Quote:
Yeah. I just got done with a factory image restore and rerooted after that.
Hi,
I made a simmilar mistake - i overwrote the build.prop of 4.2.1 with the one from 4.2. The Result: Only a Black screen on boot.
I thought it would not be that hard to get the original 4.2.1 build.prop again out of the OTA update, but it seems there is only a diff in there, not a complete build.prop. (and 4.2.1 is not (yet?) on the restore factory image page).
so, could someone upload his original build.prop from 4.2.1? Or tell me how to patch the diff for only one file myself?
Thanks a lot!
Quote:
Originally Posted by the_ac [Only registered and activated users can see links. Click Here To Register...]
wow. thats timing - now it is online :)
hope (and assume) this will fix my problem :)
