Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Like Tree7Likes
    Default Nexus 7 Bricked !!Bootloader Erased Help!!!!
    My brother erased de bootloader with "fastboot erase bootloader"...
    How can re-install de bootloader on my nexus 7?
  2. #2
    Caldera's Avatar
    Posts
    ROM
    Stock, Paranoid, CM10
    Default Re: Nexus 7 Bricked !!Bootloader Erased Help!!!!
    There is a guide right here on the forums. Check it out.
    Hey caldera thanks for the help... But i dont have bootloader. so i cant do anything of that .
  4. #4
    flipfone's Avatar
    Posts
    ROM
    JB 4.1.1
    All the images are here make sure you download the right one. the WiFi only Nexus 7 is Nakasi also you will want to know which version you had on there 4.11 4.12 or 4.2 so you can put the right bootloader back.
  5. #5
    Caldera's Avatar
    Posts
    ROM
    Quote Originally Posted by Vgarcia24 View Post
    If you can't get into recovery or flash anything through fastboot then you're probably out of luck. I'm not sure what Asus charges for this type of "repair", but it probably isn't cheap. My condolences for your loss.
    well... thanks...
    a thinks there is a way. im waiting for nvflash people... they did the same with a asus transformer...
  7. #7
    Caldera's Avatar
    Posts
    ROM
    I don't think anyone has used NVFlash with the N7 yet, but that doesn't mean it won't happen eventually. Best of luck.
  8. #8
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Wait.. so what happens when you power off and try to boot into the bootloader with volume down + power?
    nothing happens jhahaha... no bootloader on it...
  10. #10
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Time for your brother to buy you a new Nexus.
    lyingfromyou likes this.
  11. Thread Author  Thread Author    #11
    thats true... but i will keep this one. and wait for the nvflash for nexus 7.... if you news about that, please let me know..
    thanks
  12. #12
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    thanks
    Have never heard of nvflash, lol.
  13. #13
    Wow you'd think there'd be some kind of protection against that anyways there's gotta be some way to get it back they had to flash a bootloader at the factory so that means there is a way to flash it the question is how did they do it at the factory
    Sent from my Nexus 7 with CM-10 using Android Central Forums
  14. #14
    Dr0me's Avatar
    Posts
    ROM
    AOKP PUB / Franco Kernel
    Quote Originally Posted by flipfone View Post
    i think it is actually grouper nvm they chaged the name
    Quote Originally Posted by Caldera View Post
    my friend bricked his transformer and it cost like $250 bucks to fix. they replaces parts in it instead of reprogramming it.
    i also googled nvflash and it seems it only works if you have already backed up your files
    Google Android Affectionado
  15. #15
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Quote Originally Posted by Dr0me View Post
    Grouper is one codename... Nexus devices have a second codename that applies to their factory images. For example: Nexus 7 (Grouper) is nakasi (wifi only one) and nakasig (3g enabled one) ; Galaxy Nexus has a few varieties (toro = Verizon, toroplus is sprint, maguro is the gsm version) with respective image-names (mysid, takju and yakju) ; Nexus 4 (mako) is occam...
    Thanked by 2:
  16. #16
    Seems that some people have been playing with nvflash and have gotten it to recognize but haven't figured out a way of flashing anything yet at any rate there should be a way to do it soon also 2defmouze nvflash stands for Nvida flash
    Sent from my Nexus 7 with CM10 using Android Central Forums
  17. #17
    How do you erase the bootloader?
    Sent from my wireless telephonic device.
  18. #18
    With the command 'fastboot erase bootloader' check the first post
  19. #19
    Not necessary if this is rooted. Do you have custom recovery? If so, you can find the bootloader in zip format, copy it to your N7, then flash the zip from CWM or TWRP. Other wise, you made need to do a factory wipe and start from scratch. There is a way to do it from powered off state, I'll look around.
    Maxwell was the 1st "Smart" phone user......
  20. #20
    if you find something, let me know... I would be grateful
  21. #21
    Nothing at all? I erased my bootloader and when using vol down and power button I got the the android with a <start> and it would do nothing else. But when I did "fastboot reboot-bootloader" it seemed to come back. Then I reflashed the stock 4.1 zip.
  22. #22
    The android on it's back screen IS the bootloader so yeah he can't do that you erased your boot partition not your bootloader partition
    dobbs69 likes this.
  23. #23
    Quote Originally Posted by dark_samus View Post
    I wrote the command " "fastboot erase bootloader"... and thats how you erased the bootloader (i guess)...
  24. #24
    Did you find the solution? I'm wanting to try that command to see what happens now lol. I'd be hard pressed to get it working.
    So does the device even turn on? Can you adb reboot recovery?
  25. #25
    AidenSurvival's Avatar
    Posts
    Global Posts
    292 Global Posts
    ROM
    Jelly Bean
    He must have deleted the boot partition.
    Jesus, your brother is such a ****!
    I dunno 'bout you, but have you tried a toolkit?
  1. Can't get "Unlock Bootloader?" screen. HELP!
    By cowkong in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 02-12-2012, 06:48 PM
  2. BootLoader Lock help TBolt
    By jpoy808 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 09-30-2011, 01:50 PM
  3. update failed while Rooting bootloader screen HELP PLEASE!
    By Misayeh in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 04-15-2011, 10:09 PM
  4. Problems erasing .apk files. Help, please!
    By m111 in forum General Help and How To
    Last Post: 06-23-2010, 03:49 PM
  5. Having problems with Moto Droid/ Screens say Bootloader 2C.6C need help to reinstall
    By unspoken213 in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-18-2010, 03:34 PM
