Results 1 to 6 of 6
- 11-26-2012, 06:15 PM
Thread Author #1
Nexus 7 Wifi 4.2 Root issues *please help*
I'll spare you the details of how I got to where I'm at. Bottom Line is I lost root when going to 4.2 and can not for the life of me get rooted again. I'm trying to flash CM10
Anyways, these are the things I've done to try to get rerooted
1) Hard reset - doesn't work
2)manually wipe from PC (done this multiple times with evo)
3)Tried rooting with 2 different tool kits
4) Bunch of other crap for 8+ hours
Another issue is when I try to boot into recovery, it won't go into recovery mode. Any option I choose reboots my tab to lock screen. Ive deleted all drivers from PC and any and all apps that are root required ie Busybox and CWM Rom Manager
I either want to start from scratch or throw the dang thing at a wall. I love the Nexus7 but today, I've freakin had it! All issues are fully my fault and I'm hoping for mercy from the Android Gods!
I apologize if things dont make complete since as I'm seeing double and my brain is fried.
Thanks - 11-26-2012, 07:03 PM #2
- 11-26-2012, 07:10 PM #3
Re: Nexus 7 Wifi 4.2 Root issues *please help*
Follow the instructions in Zero's guide, using the files I linked to in the very last post, direct link here: http://forums.androidcentral.com/nex...ml#post2356879
[GUIDE] Nexus 4 - Unlock & Root | [GUIDE] Nexus 4 - Factory Image Restore | [GUIDE] Nexus 7 - Factory Image RestoreNeed a Dropbox? Use this link to sign up and both of us get free bonus space http://db.tt/YOHANuCI - 11-26-2012, 10:51 PM #4
i updated that thread its good to go for 4.2
*INCREDIBLE*MECHA*TORO*GROUPER* GALAXY S3 *
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 11-28-2012, 01:20 PM
Thread Author #5
Thanks for the quick response!!!
Can you recommend a program to open the .img? I've tried Deamon but it doesn't support, I downloaded magicISO which does support but it fails to mount the image on both my PCs. WinZip doesn't do me any good either and I don't have Nero, the free version is useless. - 11-28-2012, 03:26 PM #6
Nexus 7 Not Connecting to WiFi after 4.2 update, PLEASE HELP!!!
By Soham Kale in forum Google Nexus 7 TabletReplies: 27Last Post: 04-12-2013, 07:51 PM -
HTC Design Wifi Issue -- Please Help.
By Sahveen in forum General Help and How ToReplies: 1Last Post: 11-07-2012, 10:28 AM -
rooting issues. please help
By smoking rr in forum G2X Rooting, ROMs, and HacksReplies: 11Last Post: 05-27-2012, 05:27 PM -
WIFI Issues PLEASE HELP
By jegordon23 in forum AT&T CaptivateReplies: 33Last Post: 12-22-2010, 07:32 AM -
Wifi issue, please help?
By shypnoi in forum General Help and How ToReplies: 8Last Post: 12-20-2010, 08:05 AM
Reply
