Results 1 to 4 of 4
- 12-11-2012, 04:27 AM
Thread Author #1
Help! How can I use my micro USB without...
Sorry if this has been asked before, or covered elswhere, or misplaced in the wrong section.
How can I use my micro USB to connect a 3G moblie data dongle with an osg without paying for Nexus Media Importer or rooting my N7? Is it possible?
And just how is it that Google consider it acceptable to limit how I may use MY device?
Many thanks in advance for your help,
Molepox - 12-11-2012, 04:59 PM #2
Re: Help! How can I use my micro USB without...
I'm afraid I can't really answer your first question, but as to this one, it is quite simple, they don't. You are free to do whatever you want with your Nexus 7 including using it as a frisbee.
Google have their vision of how they want Android to be and they present it to you in the Nexus devices, but if you don't like it they give you the source code, they let you unlock the bootloader and flash a custom ROM, so you are free to flash a ROM someone else has customised, or you have the option to customise it yourself, I don't see how they are limiting what you can do with the hardware you bought.
And why don't you want to root your device anyway? You can't complain about limits and then say you don't want root, it doesn't make sense.
I suspect you'll need a custom ROM if you want to use a 3G dongle, I tried connecting my 3G dongle using a OTG cable (albeit without a SIM card in it because I didn't want to take the card out of my phone), the kernel recognised it, but I didn't get any options to use it (though this may be because there was no SIM card in it, but I doubt it).
Sent from my Nexus 7 using Android Central Forums - 12-20-2012, 08:25 AM #3
Limiting a device isn't the same as it just not being designed to work that way out of the box.
That's like saying Ford sucks because the car you bought doesn't fly, it wasn't meant to.
You may be able to root it and enable IP over the USB port, I haven't seen that done yet though.
Most people just root their phone, and tether over wifi to whatever device they want. - 12-27-2012, 04:18 AM #4
(Help Update Oct 22) Help? How can I UNroot my G-Nex and install stock JB,, Please?
By cashiskingnyc in forum Verizon Galaxy NexusReplies: 8Last Post: 10-26-2012, 11:13 PM -
Can you use any micro-usb cord to charge a smartphone?
By jerethi in forum General Help and How ToReplies: 9Last Post: 08-20-2012, 10:23 AM -
How can I use my SD card?
By Hurricane Moon in forum Motorola XoomReplies: 1Last Post: 04-29-2012, 02:40 PM -
How can I use my upgrade to buy a phone online?
By withravenoushunger in forum Motorola Droid XReplies: 3Last Post: 03-06-2011, 02:21 AM -
How Can I Use My Own "Ringtone" For E-Mails...
By TheNobleJustin in forum General Help and How ToReplies: 7Last Post: 11-09-2009, 11:11 PM
Reply
