[Hardware] Nexus 7 Inductive Charging Mod (using Palm Touchstones)
Got a couple of spare Palm Touchstones lying around? You can use them to inductively charge your Nexus 7:
[Only registered and activated users can see links. Click Here To Register...]
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Full details in a series of 12 posts at Google+, start at [Only registered and activated users can see links. Click Here To Register...] for the full story.
-- Rod
Re: [Hardware] Nexus 7 Inductive Charging Mod (using Palm Touchstones)
I extended this mod a bit:
-- Rod
How is the charge time on this? How quickly? I'd be more interested in getting a Qi mod since that seems to be the way things are going (albeit more expensive). I found a video on youtube from a guy ([Only registered and activated users can see links. Click Here To Register...]) where he used the Qi coil and board from the BB 8900 Energizer back plate to make it work. I ordered the iphone 3 one to try and fit it. It would be interesting to compare results. Any plans to do a Qi one?
The idea of inductive charging is that you have one at home and one at work and then you don't care what charging time is cause your device is always fully charged unless you're out.
Since I don't have any Qi devices, no plans for a Qi mod at this time.
-- Rod
Now I have four of them :)
-- Rod
