Results 1 to 4 of 4
- 12-29-2012, 12:30 PM
Thread Author #1
A couple questions about rooting. Is it always fixable, best way on a mac, and such.
So, onto the questions.
1. What are the possible ways of permabricking it, I am 14, and thus have little money. I am fairly confident I can fix anything fixable with software.
2. I have a Mac, 10.8. I theoretically have access to a winxp laptop. That is about it. Best way to unlock/root?
Thanks in advance
- 12-29-2012, 03:52 PM #2
Re: A couple questions about rooting. Is it always fixable, best way on a mac, and such.
yes root is fixable as long as you don't go and try to build your own system and replace android with it then you might screw up the restore file but if u use data clear your phone will still be rooted (and have superuser) the easiest way is to use superoneclick on winxp it wont actually install on the computer and is so easy i did it and didnt even know it worked its like installing a app and wont really do anything to you phone in the rooting process its more what you do after
- 12-29-2012, 04:16 PM
Thread Author #3
- 12-30-2012, 02:19 PM #4
By DroidBehavior in forum AT&T Galaxy S IIReplies: 1Last Post: 11-04-2011, 04:50 AM -
Question about rooting....
By NCREDIBLE GARY in forum Motorola Droid Rooting, ROMs and HacksReplies: 3Last Post: 03-02-2010, 10:52 AM -
Im probably one of the most clued out person. but a few questions about "rooting"
By samster in forum Motorola Droid Rooting, ROMs and HacksReplies: 6Last Post: 02-16-2010, 08:45 PM -
Have a couple questions about rooting my droid
By mjesenovec in forum Motorola Droid Rooting, ROMs and HacksReplies: 25Last Post: 02-11-2010, 03:02 PM -
By smccloud in forum HTC Hero Rooting, ROMs, and HacksReplies: 4Last Post: 01-09-2010, 12:40 AM
Reply
