Results 1 to 4 of 4
    bergerdml's Avatar
    Posts
    Global Posts
    20 Global Posts
    Default Help me upgrade TWRP Nexus 7 to 4.2.2
    I have nexus 7 running android 4.2.1 and TWRP boot loader. The OTA upgrade doesn't work (presumably because of TWRP). Can someone explain to me how I am supposed to upgrade the Nexus 7 to 4.2.2 maintaining TWRP and root?
    I would imagine that this should be simple and straight forward, but I cannot figure out how to actually do this. I have poked around for a howto but have only found ways to flash from scratch.
    Any help would be greatly appreciated.
    Sent from my Nexus 7 using Tapatalk HD
  2. #2
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Default Re: Help me upgrade TWRP Nexus 7 to 4.2.2
    The simplest way would be to use wug's root tool (). It has been reported, but not verified, that 4.2.2 needs the new bootloader to work correctly. So you can use wugs to flash to the new OS, then reapply twrp, and inject superuser.
  3. #3
    I had the same problem, a nexus 7 with 4.2.1 and TWRP boot loader, but I have windows 8 and still should work the same if your using windows 7. You can't update it through normal OTA methods, you have to flash a stock factory img. to remove TWRP and then update to 4.2.2 and reroot. I followed the video guide in 2defmouze's guide, to flash my nexus 7 back to stock 4.2.1. I updated by going into settings, apps, slide over to "all", and scrolled down to "google services framework", clicked "cleaned data" and "clear cache", went back to settings, scrolled down and clicked "about tablet", clicked "system updates" and waited for it to update. I then used Wug's toolkit to unlock and root. It installs TWRP or you can install a different recovery and flash over different img. which is nice. Hopefully that should work for you.
  4. #4
    A-android-B's Avatar
    Posts
    ROM
    it changes so much
    I have successfully flashed jdq39 with multirom twrp recovery by tassador. Just download it from Google and flash in fastboot.
    ** these are just words **
    beamed from the mothership...
    but its only a proxy for my
    lubuntu 12.04
  1. Help Me Convince My Mother to Get a Nexus 10 Instead of an Ipad
    By androidluvr2 in forum Google Nexus 10 Tablet
    Last Post: 04-20-2013, 10:19 PM
  2. Help - me switch from Pre- to Epic 4G Touch
    By luigidk in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-23-2011, 03:44 PM
  3. Replies: 9
    Last Post: 05-09-2011, 05:31 PM
  4. Help me find a comprehensive to-do list/calendar
    By Emmlet83 in forum Android Applications
    Last Post: 05-04-2011, 02:02 PM
  5. Help me Decide which Device to get
    By Gerane in forum General Help and How To
    Last Post: 11-26-2010, 06:42 AM
