O oldfartking Member Feb 24, 2012 7 0 0 Visit site Feb 4, 2017 #1 Ring tone can not be turned off by slider. This is a problem in a office setting. This was not a problem before 7.0.2 update. This is unacceptable and has turned my opinion about my 0p3.
M mchockeyvette27 Well-known member Jun 15, 2011 1,539 0 0 Visit site Feb 5, 2017 #2 If you are talking about the fact that you can't turn the volume all the way down with the volume button anymore, this has been touched on. Unfortunately it is just a change made in the software. There's a couple workarounds here: https://forums.androidcentral.com/o...3-vibrate-sound-toggle-possible-solution.html Otherwise, to put it into silent or vibrate, you will have to use the volume toggle above the volume rocker.
speedlever Trusted Member Dec 31, 2011 664 0 0 Visit site Feb 5, 2017 #3 Er, maybe the alert slider? Top position, gear icon, enable vibration.
