Results 1 to 3 of 3
    stephentheh's Avatar
    Posts
    Global Posts
    15 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Disable camera shutter sound?
    Does anyone have experience disabling the shutter sound on the Elite?
    Having rooted my phone, I tried renaming/deleting the shutter sound files in /system/media/audio/ui but that doesn't seem to work for the stock camera app. It did do the trick to remove the shutter sound though if I use other apps like Camera360 and Vignette, but sometimes I like to use the stock app too, and the shutter sound always seems to ruin the mood. Also, all the apps on the marketplace that seem to "solve" the problem will shut off ALL sound, which is a hassle because then you have to turn it back on.
    Anyone have any tips or ideas?
  2. #2
    Swagroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Disable camera shutter sound?
    Go to android forums that did that a longggg time ago or just get a new rom
    Sent from my LG-VM696 rooted "bonestock"
  3. #3
    itsthekidbigc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you are rooted head over to /system its under media/audio/ui delete everything that sounds related to cam
    Sent from my LG-VM696 using Tapatalk 2
  1. Disable Camera shutter sound?
    By bjones521 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-01-2011, 12:03 AM
  2. Camera Shutter Sound stopped ?!
    By jlewis in forum Sprint Photon
    Last Post: 11-22-2011, 11:43 PM
  3. disable camera shutter sound?
    By ufergus in forum Motorola Xoom
    Last Post: 04-27-2011, 05:22 PM
  4. Camera shutter sound not working...
    By AisforAustin in forum Verizon HTC Thunderbolt
    Last Post: 04-11-2011, 12:22 AM
  5. Re-enable camera shutter sound
    By dcreed in forum Motorola Droid
    Last Post: 10-13-2010, 02:29 PM
