Results 1 to 3 of 3
    kenharkey7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    [TeamFC] MiuiAndroid
    Default [ROM][PORT][WIP] Paranoid Android 3.0
    So here it is, the new rom i've been working on. It's currently in a WIP state and I need help testing it. This post will be updated as things progress.
    Ported from the Xperia J [ROM][4.1.2][Tipo/J][Paranoid Android 3.0][UPDATE 13/04/2013 For J] - xda-developers
    Based on the latest version of Phenom's CM10 with latest camera patch
    What needs to be fixed:
    # USB Mass storage (again)
    # Paranoid Settings
    Everything else should work normally as long as it works in the cm10 rom.
    Files are now here
    http://www.androidfilehost.com/?w=files&flid=12184
  2. #2
    DRAGSLiCKS's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM][PORT][WIP] Paranoid Android 3.0
    Hi, I'm new here, I'll help you test it. What kernel do you recommend to use with this ROM?
    kenharkey7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I appreciate it but this rom is pretty much dead, better things have happened since then
  1. [ROM] Touchwiz for the optimus elite final updated 1-21-14
    By kenharkey7 in forum Optimus Elite Rooting, ROMs, and Hacks
    Last Post: 02-27-2015, 05:58 PM
  2. [ROM][PORT] SlimBean 3.10 updated 1-21-14
    Last Post: 12-09-2014, 07:49 PM
  3. [ROM][TW4.3][MK3] ヅ Wicked Sensations Rom v0.2 ✭myHUB✭Clock Mod✭Awesomeness✭1/6/2014
    By seanskiT1 in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 04-02-2014, 09:01 PM
  4. Replies: 1
    Last Post: 01-22-2014, 02:00 PM
  5. [ROM][PORT] MIUI v4 3.2.22 Unofficial
    Last Post: 01-19-2014, 06:13 PM
