Results 1 to 5 of 5
    Wesley Adames's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default lg optimus elite kit kat?
    Will there be a cyanogenmod 11 for the optimus elite?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,761 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: lg optimus elite kit kat?
    Quote Originally Posted by Wesley Adames View Post
    Officially, it doesn't look like it's a supported device. Check the forums and see if there is someone working on bringing CM11 to your device.
  3. #3
    kenharkey7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    [TeamFC] MiuiAndroid
    Actually yes there is KK for the elite. Just not on this forum and it's against the rules for me to link to it. However I am working myself on bringing two KK roms to the elite, Gummy and Carbon so look out for those. Should have something very shortly
  4. #4
    Seanw684's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes there is kit kat for the elite, http://androidforums.com/elite-all-t...13-2014-a.html
    it is cm11, I am currently running it, the newest maps has no glitches for me, and I highly recommend overclocking 1600Mhz, it is stable clock for most, also disable the force 2d rendering option; all these tweaks are accessible by enabling developer mode (google it).
  5. #5
    MTDiallo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i am unable to download the gapps file once i click on the link. is it working for you?
  1. LG G2: Remove lock screen animations?
    By TouchPerception in forum LG G2
    Last Post: 03-06-2015, 03:26 PM
  2. com.google.process.gapps has stopped lg g2
    By Josh1303 in forum LG G2
    Last Post: 04-28-2014, 06:42 PM
  3. KIt Kat update messed up my email
    By mmohn01 in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-29-2014, 11:09 AM
  4. LG g2 bluetooth drain.
    By Taripin in forum AT&T LG G2
    Last Post: 03-28-2014, 04:13 PM
