I want to know how you guys actually use some of these roms I have tried the newest AOKP rom which runs great :~D But lags the **** out of my phone after a while(Even after tweaks and what not) I also tried the CM9 rom works great but after a few days I start lagging, just like the aokp. I finaly settled to sleipnir(sorta?)I love this rom because it is so fast (with and without tweaks) Recently that rom gave me problems, I downloaded clean master and I go into a bootloop... It takes 7 mins to load up then I try using it and reboot. I definatley think it is clean master as I downloaded it twice and It does the same(This should be a warning if you use sleipnir) Okay well why I really made this thread is not to complain about these awesome roms(Thanks to all the devs who made and ported) I really want to know how some of you guys have you elite setup( What rom are you running? Tweaks? How is the battery? Does it lagg?) I tried a couple of roms CM9, Slimbean, Slimkat, CM10, AOKP, Sleipnir. I do like speed in my phone which sleipnir provides. But I also want to have 4.0+(With speed and not much of a battery hog) So is there anything like it? Or is it time to just upgrade phone(Yep...)
