- 07-18-2012, 05:56 AM
Thread Author #51
Re: [ROM][CyanogenMod9/AOKP][WIP][THEMED]VanillaBean
Happy Nexus 4 User
- 07-18-2012, 07:15 AM #52
Just flashed this while at work. So far so good. Definitely digging it. Will play with it tonight.
Sent from my LG-VM670 using Android Central Forums - 07-18-2012, 08:38 AM #53
I used Leslie's prep zip as I always do. I'll try messing with settings and such and maybe try one more flash. Not being and to use Google Now won't keep me from using the ROM at all
- 07-18-2012, 02:16 PM #54
Its alright
Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2 - 07-18-2012, 08:23 PM #55
I get fc's with Google search widget and the Google music player...any ideas?
Sent from my LG-VM670 using Android Central Forums - 07-18-2012, 09:17 PM #56
- 07-18-2012, 09:22 PM #57
- 07-18-2012, 10:20 PM #58
How do I do that?
I tried to change dalvik heap size from 128m to 145m using es file explorer...it gave me an error trying to save it
Sent from my LG-VM670 using Android Central ForumsLast edited by sellersj27; 07-18-2012 at 10:31 PM.
- 07-18-2012, 10:41 PM #59
- 07-18-2012, 11:48 PM #60
Worked like a charm! I changed dalvik heap from 128 to 150. Still got the fc's... but learned how to edit build props!
Sent from my LG-VM670 using Android Central Forums - 07-18-2012, 11:52 PM #61
- 07-18-2012, 11:58 PM #62
- 07-19-2012, 12:00 AM #63
- 07-19-2012, 12:03 AM #64
- 07-19-2012, 12:10 AM #65
Go to mounts and storage in recovery and mount system, then go to flash zip from sdcard and flash it.
- 07-19-2012, 12:11 AM #66
- 07-19-2012, 12:17 AM #67
Seems nice so far
Sent from my LG-VM670 using Android Central Forums - 07-19-2012, 12:21 AM #68
- 07-19-2012, 12:23 AM #69
- 07-19-2012, 12:29 AM #70
- 07-19-2012, 12:39 AM #71
- 07-19-2012, 02:02 AM
Thread Author #72
I've actually seen that file and it's among my VanillaBean builds\JB files\Apps\ICS\APKTool\Random other JB stuff to port over on my Flash Drive. If i can successfully decompile Framework-res ill put them in :P
Happy Nexus 4 User
Thanked by: - 07-19-2012, 02:12 AM #73
Try decompiling the originial framewrork-res then do what you need to do then recompile it. Then use 7zip to edit the png's.
Sent from my shole using Tapatalk 2 - 07-19-2012, 10:24 AM
Thread Author #74
When I decompile it/recompile it via APKTool I get issues in both things. False files, exceptions, and the like.
As for editing images- isn't it more complicated then just replacing the images in 7z?Happy Nexus 4 User
- 07-19-2012, 01:19 PM #75
Nope
