[ROM][CyanogenMod9/AOKP][WIP][THEMED]VanillaBean
Status
Not open for further replies.
Zakman
492
185
Yeah, but they don't seem exactly like JB. Apps open in a smooth transition, but they don't open from the apps location...if you know what I mean :p
In the thread they said they were ripped from jelly bean but idk.
TauSigmaNova
Domo Arigato, Mr Roboto!
Mar 14, 2012
323
83
I've actually seen that file and it's among my VanillaBean builds\JB files\Apps\ICS\APKTool\Random other JB stuff to port over on my Flash Drive. If i can successfully decompile Framework-res ill put them in :p
Reactions: JadenBrown30
Nate456
462
120
Try decompiling the originial framewrork-res then do what you need to do then recompile it. Then use 7zip to edit the png's.
Sent from my shole using Tapatalk 2
TauSigmaNova
Mar 14, 2012
323
83
When I decompile it/recompile it via APKTool I get issues in both things. False files, exceptions, and the like.
As for editing images- isn't it more complicated then just replacing the images in 7z?
bedrockhorror
9
I installed this rom, everything is going good so far except for the google now. It keeps throwing the google search has stopped working error when it tries to run. Also I don't know what it is but the standard email client won't connect either. It gets stuck on checking incoming server settings, then just closes. I know the information is correct.
Zakman
492
185
What I would do is flash ur current rom then flash my zip the from root explorer copy the framework-res file to the sdcard and use that.
StingDrop
133
18
Could I suggest using a sprint prl maybe inverted mms other then that works great
Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
LeoLawliet
713
108
About to flash this in a while, I wonder how Jellybean development is going for our device?
Sent from my LG-E739 using Tapatalk 2
Status
Akshay
