- 07-18-2012, 09:32 PM
Thread Author #1
[GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stock
Use this instead [GUIDE] Unbrick/Upgrade Optimus V [EASY] [KDZ]
because this is obsolete as well as second post.
This can also be used if you wanted to downgrade/upgrade/return to stock.
But a better way to do so is in the second post.
[INFO]
Things Needed, Downloaded, Extracted:
Install Drivers: look
Install this program:
Then open the program, let it load, close it.
Download KP500 Tools:
Download this ZV5 cab containing VM670ZV5 FW that I fixed to work with KP500 Tool:
Extract KP500 to the root of your hard drive, meaning extract everything to C:\KP500-Utils-En
Move ZV5.cab to C:\KP500-Utils-EN[/INFO]
If you have problems following this, watch this YouTube video that asadullah made. Big Thanks to him
[YT]http://www.youtube.com/watch?v=__NUDkxQzEg&feature=youtube_gdata_player[/YT]
[BOX="Steps:"]Step 1: Download/Install/Extract everything above, it is VERY important that you extract everything to the proper locations.
Step 2: Put the phone in emergency mode:
-Turn phone off, unplug USB, remove battery, reinsert battery.
-Press Volume Down+Back Key+Plug in USB to computer.
Note: Connect USB cable directly into USB port, don't use a USB HUB/splitter!
Step 3: (Vista, Windows 7 users only, skip if running Windows XP) Right click KP500-Utils-EN.exe located in C:\KP500-Utils-EN folder, Click "Properties", click "Compatibility" tab, Checkmark "Run this program as an Administrator", Press Ok.
Step 4: Open C:\ and hold shift while right-clicking KP500-Utils-EN folder and press "Open command window here"
Step 5: Copy and paste these commands (press enter after pasting each command):
If it says to Restart with a pop-up window, unplug USB cable, plug back in, Click Restart.Code:KP500-Utils-EN J VM670 C:\KP500-Utils-EN\ZV5.cab ZV5
If it says to Restart without a pop-up window, unplug USB, pull battery, plug in USB, Click Restart.[/BOX]
[INFO]If it flashes and reaches 99% and fails/stops, check the phone:
1. If it's in recovery, press wipe data (factory reset), then reboot
2. If it is in charge only mode, press power button until it turns on.
3. If it's in the phone, you're done
:cheers: [/INFO]
Thanks to Phatninja55 for doing absolutly nothing, and then asking for credit. Just kidding, he helped give me some ideas to get this FW flashing
What I'm working on:
Fixing ZV4 to flash with KP500DONE!
Please PM me for ZV4 firmware fixed for KP500. DO NOT post in thread asking for it.
Why does LG release borked FW and not able to fix it, but me, a 17 year old is able to??
smh LG.
Anyone know of any other borked firmware from LG? PM me.
Need a kdz to be a cab file? PM me.
Need a cab to be a kdz file? PM me.
Need a wdb file extracted? PM me.
Need an unbrick method for an LG phone? PM me.
Like my work? Did I just save your phone?
Want to do more than hit the thanks button?
Donate . Thank You
Thanked by 6: - 07-18-2012, 09:33 PM
Thread Author #2
- 07-18-2012, 09:44 PM #3
Re: [GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 FW
Thread stuck.
--Chris [cole2kb]
"Any story about malware on any platform...without numbers is not giving you the full picture, and just might be more worried about getting your clicks than any real discussion."
Words to live by: there are always two sides to every story.Thanked by 2: - 07-19-2012, 05:45 PM
Thread Author #4
Re: [GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stoc
OP updated....the ZV5 link was wrong...O.o I don't know what happened....-_- fixed it
- 07-20-2012, 07:23 AM #5
i'm not sure phatninja55 would be ok with being called phatnina55
- 07-20-2012, 09:13 AM
Thread Author #6
- 07-20-2012, 01:40 PM #7
Doesn't bother me at all. I never look here. I'm always on AF.
- 07-20-2012, 01:54 PM
Thread Author #8
- 07-20-2012, 04:34 PM #9
Couple things.
1st, thanks man! This is freaking awesome.
2nd, does this method help retain all of the data information? Like, in the old unbrick method, you had to do a bunch of stuff to get mobile data working again.
3rd, why do you have to rename the .cab to that?
Finally, is there anyway you can extract just the rom, and that way return to stock without changing radio?Olan Rogers, ladies and gentlemen. Funniest video ever!!!Thanked by: - 07-20-2012, 06:30 PM
Thread Author #10
Yes it retains all MEID/MDN/MIN/MSID/PRL/AAA/HA information, otherwise there would be no point of getting the cab to work with KP500.
For the second post, the cab was renamed wrong before it was uploaded, its a different cab from the first post. If you try flashing the second cab with LGNPST and not rename it you will get an error, then when you rename it, it will work fine
and if you or someone else could do me a favor and flash my cab from the first post with LGNPST and tell me if it flashes or not, that would be awesome
And for the last thing, not that I know of.
Sent from my Optimus M - 07-20-2012, 06:50 PM #11
If I backedup my quattrimus, did this, rooted and installed custom recovery again, could I restore my backup and have a different radio? Don't really wanna lose everything yet
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-20-2012, 06:54 PM
Thread Author #12
- 07-20-2012, 08:06 PM #13
Okay. Is there a way to upgrade to zv9 using this method? I live in a place with bad reception and get better reception with zv9, so if I test this, I wanna go back quick.and I can't test til at least Sunday.
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-20-2012, 09:32 PM
Thread Author #14
- 07-21-2012, 06:12 AM #15
Yeah, forgot about the name on here. Who would I pm to get it changed?
- 07-21-2012, 07:54 AM
Thread Author #16
- 07-21-2012, 10:33 PM
Thread Author #17
OP updated:
I fixed the ZV4 firmware to work with KP500
PM me if you want it. (Must have old screen/advanced user)
Please DO NOT post in this thread asking for it, you WILL be ignored. - 07-22-2012, 12:12 PM #18
Why would you want zv4?
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-22-2012, 01:12 PM
Thread Author #19
Thanked by: - 07-22-2012, 04:53 PM #20
Greetings to all,
Followed Instructions Correctly, However...
Could not Start the flash.
Re-Try occurs several times at the
"14:44:30 : Model Dll Msg Not Found(20, 570)" Message prompt
My VM670 now only boots to the LG Logo and "Download is in progress. Do not Disconnect Cable." Screen ( No red Emergency Mode at the bottom )
Log is Here:
4:43:35 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
14:43:35 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
14:43:35 : Start Date : 2012-07-22 14:43:35
14:43:35 : -------- Buyer Test mode ---------
14:43:35 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
14:43:35 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
14:43:35 : *****CheckOS Start********
14:43:35 : Microsoft_Windows_Vista Professional_
14:43:35 : *****CheckPCSyncPrograms Start*****
14:43:36 : PCSyncPrograms Not Found
14:43:36 : SetEmerModeAT()
14:43:36 : _IsConnectedPhone Call
14:43:43 : _IsConnectedPhone(2)
14:43:43 : 0 - NotConnected.
14:43:43 : 1 - Normal connect success
14:43:43 : 2 - Emergency connect success
14:43:58 : Checking the connection with the cell phone...
14:43:58 : dwWaitResetTime(40000 ms)
14:43:59 : Phone Mode(2)
14:43:59 : *****GetPhoneType Start*****
14:44:02 : Phone Type : CDMA
14:44:02 : *****Start GetPreviousStep*****
14:44:02 : _GetPreviousStep(dwStep:0x5)
14:44:02 : *****GetPhoneBinaryVersion Start*****
14:44:02 : CSE mode -> Version Replace
14:44:02 : *****Get ESN / IMEI / MEID Start*****
14:44:14 : *****GetPhoneNumber Start*****
14:44:16 : Phone Number : 00000000000
14:44:17 : ÀÎÁõ °Ë»ç ÆÄ¶ó¸ÞŸ - ESN_IMEI : 00000000000, Model :
14:44:19 : _GetAuthMark : wAuthMark(12743)
14:44:19 : Wait 3Sec
14:44:25 : _SetAuthMark Ok : wAuthMark(12743), PhoneMode(2)
14:44:25 : *****CheckPCSyncPrograms Start*****
14:44:25 : PCSyncPrograms Not Found
14:44:26 : CLGMobileHttp Class ¼Ò¸ê½ÃÀÛ.
14:44:26 : CLGMobileHttp Class ¼Ò¸ê...
14:44:26 : ****************CheckAndDownload********************
14:44:26 : ******Extract Start C:\KP500-Utils-EN\ZV5.cab*****
14:44:26 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
14:44:27 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\ZV5.wdb\n
14:44:27 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\ZV5.wdb)
14:44:27 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll\n
14:44:27 : Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll)
14:44:27 : NNNNN WDB FullPath(C:\ProgramData\LGMOBILEAX\Phone\ZV5.wdb)
14:44:27 : NNNNN Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
14:44:27 : Extract End C:\KP500-Utils-EN\ZV5.cab
14:44:27 : *****WorkModelDLL Start*****
14:44:28 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone\ZV5.wdb)
14:44:28 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
14:44:28 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
14:44:28 : m_nPhoneMode(2)
14:44:28 : Phone mode 1 = Normal
14:44:28 : Phone mode 2 = Emergency
14:44:28 : Phone mode 4 = CSE
14:44:28 : _DetachDLL Call
14:44:28 : _DetachDLL Call End
14:44:28 : Call fn_StartUpgrade
14:44:28 : ### Start Upgrade - CDMA ###
14:44:28 : ********* CDMA Model.dll input Parameter *************
14:44:28 : MODEL_EVENT : 32769
14:44:28 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\ZV5.wdb
14:44:28 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
14:44:28 : BootWaitTime : 49500
14:44:28 : UsbHighSpeed : FALSE
14:44:28 : PhoneMode : 2
14:44:28 : NewPhoneBinVersion : ZV5
14:44:28 : ClearSI : FALSE
14:44:28 : AuthMark : 12743
14:44:28 : ********* CDMA Model.dll input Parameter End*************
14:44:29 : wParam : 20, lParam = 570
14:44:29 : MODEL DLL Event : (20, 570)
14:44:34 : wParam : 6, lParam = 0
14:44:34 : MODEL DLL Event : (6, 0)
14:44:35 : wParam : 100, lParam = 84
14:44:35 : MODEL DLL Event : (100, 84)
14:44:35 : CleanModelDll() : Free Model.dll
14:44:35 : _DetachDLL Call
14:44:35 : _DetachDLL Call End
14:44:35 : FreeLibrary Call
14:44:37 : FreeLibrary Call End
14:44:37 : wParam : 20, lParam = 0
14:44:37 : MODEL DLL Event : (20, 0)
14:44:37 : Model Dll Msg Not Found(20, 0)
14:44:37 : Page_Error ºÎºÐÀÔ´Ï´Ù
14:44:37 : ¿©±â´Â Retry ºÎºÐÀÔ´Ï´Ù
I Re-Tried plugging in the cable several times and following the prompts and then re-starting the process over many times with no success.
Any help would be appreciated. :-)
Thanks,
Rick - 07-22-2012, 06:32 PM #21
It could be a drivers problem. You sure you have the correct drivers??
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 07-22-2012, 06:33 PM
Thread Author #22
@Rick Unplug USB, pull battery, insert battery, plug in USB, DO NOT do the key combination to put it in e-mode only when it says to restart the second time.
- 07-23-2012, 01:01 PM #23
my computer refuses to pick up the serial ports.
Guess whos coming back! - 07-23-2012, 01:06 PM
Thread Author #24
- 07-23-2012, 01:13 PM #25Guess whos coming back!
