DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Like Tree4Likes
    Default [AIO][WIP] Romtools by Phatninja55
    Since I'm to lazy to continue this, I will be asking for this to post to be removed. Plus RomManger soon shall be compatible with out phones.
    Thanked by 5:
    PatrickAkridge likes this.
  2. #2
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Default Re: Romtools v1 by Phatninja55
    Flash recovery on what????????
    Unrooted phone???
    OMG!!!
    I am trying this!
    Need to install ubuntu...
  3. #3
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    nice work man!... this will help alot of people!...
  4. #4
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Default
    Quote Originally Posted by sammyz View Post
    Unrooted phone???
    OMG!!!
    I am trying this!
    I'm guessing it must use the gordita exploit to accomplish that. Still a pretty cool tool.
    Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
  5. #5
    sammyz's Avatar
    Posts
    ROM
    Quote Originally Posted by thewraith420 View Post
    It doesn't.....he actually was unable to get that downloaded....
    It does, it uses the same command for getting correct permissions to flash recovery....
    Uploaded romtools for windows. If there is anything you want me to add, modify, or remove, please feel free to let me know.
    sammyz likes this.
    Edited windows version to include adb, less files, and a bin folder, because of all the changes I have bumped it up to V2. Linux remains the same, other than small tweaks and such.
    Thanked by:
    sammyz
  8. #8
    EarthnFire78's Avatar
    YAY!!! ME :)
    Posts
    ROM
    Custom ROM & Kernel
    Default Re: Romtools v1+v2 by Phatninja55
    If you like I can edit the main script for Linux to flash any ROM without having to rename it update.zip? Do not ask me about Windows I'm not really good with Windows Batch files.
    Quote Originally Posted by EarthnFire78 View Post
    Go right ahead. I could probably change it to work with windows. I'm not that great with either scripting types. Just enough to get a good working script.
  10. #10
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    Can you use this to flash tons without flashing, or do you still have to wipe? Perhaps you could add that into the options? This could really help for those blank recoveries.
    Olan Rogers, ladies and gentlemen. Funniest video ever!!!
  11. #11
    sammyz's Avatar
    Posts
    ROM
    Quote Originally Posted by andrewnelson23 View Post
    It has automatic wiping process but to flash ROM, you must have a recovery that has signature verification off by default, or an actual signed ROM....
  12. Thread Author  Thread Author    #12
    I just added an option to sign a zip. =d
    Might stop production on linux. Windows only from now on, will keep v1 for linux up tho.
    Thanked by 2:
  13. Thread Author  Thread Author    #13
    Edited OP with version 2.5 of Romtools for windows. Linux will no longer receive updates.
  14. #14
    sammyz's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by Phatninja55 View Post
    You need to add the virgin mobile mms patcher and add instructions how to use it.
    Sent from my Optimus V running Optimus S firmware on MetroPCS
  15. Thread Author  Thread Author    #15
    Default Re: [WIP] Romtools v1 (Linux) and v2.5 (Windows) by Phatninja55
    That would be way to much work. It would ruin the simplicity of the tool.
  16. #16
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    why no linux updates? thats all I use...
    Guess whos coming back!
  17. #17
    flapjack.fiasco's Avatar
    Posts
    ROM
    Cold As Ice - Alpha 19e
    You've got to be ready for everything! Dual boot and/or use VMs.
    Last edited by flapjack.fiasco; 07-28-2012 at 12:13 AM. Reason: Left out the quote initially.
    This space intentionally left blank.
  18. Thread Author  Thread Author    #18
    I do. Ubuntu 10.04, and Windows 7. I'm just not that great at bash scripting. I actually started working on the bash script again, just never said anything about it. I will soon have it up to par with the windows version.
    Last edited by Phatninja55; 07-28-2012 at 12:36 AM. Reason: Fixed misspelled word.
    flapjack.fiasco likes this.
  19. Thread Author  Thread Author    #19
    Minor changes, fixed some spelling.
  20. #20
    sammyz's Avatar
    Posts
    ROM
    Fix your signature
  21. #21
    YAY!!! ME :)
    Posts
    ROM
    Custom ROM & Kernel
    WARNING!!!! This tools is not compatible with CWM-Blue-Recovery any version, it well cause the rom to not install and well trigger auto backup after easing everything, causing the fastboot mode when rebooted.
    @ Phatninja55 I have edit the mean script for the Linux version to flash any rom zip without the need to rename it to update.zip.
  22. Thread Author  Thread Author    #22
    I already did that for windows, and am working on updating the linux version so it's up to par with the windows version.
  23. #23
    YAY!!! ME :)
    Posts
    ROM
    Custom ROM & Kernel
    Okay, if you need help with bash/shell scripts let me know. Can you update the OP about CWM-Blue-Recovery, that way Romtools users are aware that it is not compatible? It well also help me with support of the Recovery.
  24. Thread Author  Thread Author    #24
    I'm good. I have completed it, I'm uploading it now. You now have to type the name of the rom file, patch file, or recovery file.
  25. Thread Author  Thread Author    #25
    Default Re: [WIP] Romtools V2.5.2 by Phatninja55
    Romtools V2.5.2 is now almost 100% the same for Windows and Linux. Linux has an extra step to fix script permissions. Removed push to phone.
