Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Like Tree5Likes
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default [ROM][WIP][ZVJ]Cross Bread Gingerbread
    Hello all this is sort of a discussion thread for my upcoming rom will add downloads when finished but for now its just discussion
    Hello there welcome to cross bread gingerbread this is a rom based off of jtsnp stock rooted base rom .
    This is meant for OPTIMUS V ZVJ DONT FLASH UNLESS YOUR ON IT!!!!!!
    Flash at your own risk
    What this is and not
    This is a tweaked rom for the optimus v
    This is tweaked for performance
    This is NOT created by me
    Now here are the features
    Amphetimes
    Adrenaline engine
    Beats audio+xloud
    Themed
    Good battery life
    Removed boot sound
    Better launcher
    No sprint stuff
    Build.prop tweaks
    Deleted some things not needed
    Htc-ime keyboard
    Thanks
    Torch2424-inspiring me
    Jtsnp-base rom
    Sammyz-for OV zvj
    RedBaron-for your tweak
    Dhruv.always-pm'ed u a couple times this month no reply I included ur beats if you don't want me too I will take out
    Me-for tweaking
    ThatGuyLurkin-teaching me about everything I know he's like a Jedi master I'm a apprentice
    Hlxanthus-for htc -ime keyboard idea
    [ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
    Imbawind-adrenaline engine.
    I will give out test builds soon but for now no downloads until I'm done with it
    Also the tweak for switched basebands may not work
    Pleeeease flash hydro kernel I want u too lg stock kernel suckz
    Here it is
    [KERNEL][GB/ICS] HydroKernel v01pre4 (OC Enabled!)
    Or iscream kernel your choice
    [KERNEL][GB/CM9] iScream Kernel v01 (ICS, baby!)
    Also here's ginger kernel
    [KERNEL][GB] GingerKernel v08.1 (OC) DOUBLE-TAPPING BUG FIXED!!!
    Kernels are optional but recommended since these you can OC your phone with
    Try the patch in this thread if your on zv4 ect all the way to 9
    [Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus V)
    How to install
    Reboot recovery
    Backup
    Wipe everything
    Disable signature verification
    Flash rom
    Flash kernel (please or it WILL be slow)
    Reboot
    Profit
    Give me thx or likes
    Flash this for extended power menu
    [MOD]Extended Power Menu - ZVJ ONLY
    Just wipe caches
    Will try to get permission to include
    Download-today or tommorow
    Bugs:thumbdown::thumbdown:
    When you first boot up you get a fc with update something I'm on it
    Sorta slow without hydro kernel
    Can't download zip files it WILL say....download failed or something
    That's all
    Sent from my LG-LS670 using Android Central Forums
  2. Thread Author  Thread Author    #2
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
  3. #3
    Nate456's Avatar
    Posts
    ROM
    Stock, CM10, AOKP
    Default
    First
    May wanna put WIP in the title.
    Sent from my shole using Tapatalk 2
    Thanked by:
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by Nate456 View Post
    First
    Yup right
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Can anyone help me out?
    I replaced the keypad folder I got OS buttons
    I replaced usr folder got OS buttons can anyone help thx after that I will give out tests
    Sent from my VM670 using Android Central Forums
  6. #6
    ilikechicken123's Avatar
    Posts
    ROM
    MiRaGe
    Default Re: [ROM][WIP][ZVJ]Cross Bread Gingerbread
    I could use this with the ZVJ ZVD patch?
  7. #7
    Please don't include any Beats stuff.
    Sprint Gingerbread has WAY better sound quality than IHO and CM9.
    Adrenaline Engine, isn't that just the terminal command. Basically, a ' task killer '.
    Also, Release Test Builds in public. o_O
  8. #8
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by jonny5449 View Post
    No offense but you really need to learn to do all this yourself.
    Guess whos coming back!
    Thanked by 2:
    kcls and ThatGuyLurkin like this.
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by ThatGuyLurkin View Post
    As you wish
    As soon as I get buttons I will release build
    @sellers
    I understand
    @everyone
    I can release it but will have wrong buttons maybe the patch will work????
    Thanked by:
  10. #10
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    if you tell him how to do it, he's learning, right?
    this rom is zvj....but there's like a total of maybe three people on zvj right now. haha
    Olan Rogers, ladies and gentlemen. Funniest video ever!!!
  11. #11
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Quote Originally Posted by andrewnelson23 View Post
    No, you misunderstood me. He can ask, but he keeps asking people to do it for him. Thats not learning.
  12. #12
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Default
    Keys 139 and 102 need to be switched in qwerty.kl and thunderc.kl
    Sent from my VM670 using Tapatalk 2
    Thanked by 2:
  13. #13
    Posts
    ROM
    Quattrimus
    You need to go to /system/usr/keylayout. Then choose thunderc_keypad.kl and edit the keys in there. you just need to switch the home and menu buttons.
  14. #14
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Default
    Look at nitestalkrs patch, it is a single file you replace....not an entire folder.
    Sent from my Optimus V running OSZVJ firmware on MetroPCS using HydroROM.
    Thanked by:
  15. #15
    Posts
    ROM
    Changes Daily
    Default
    Oh and I'd gladly test since I'm one of the few currently on zvj with my OV
  16. #16
    Posts
    ROM
    Quattrimus
    -_- I'll test with a patch. but thus far, I have not been able to get service on zvj roms with the patch.
  17. Thread Author  Thread Author    #17
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Well will do the key thing tommorow thanks guys I will add you to thanks
    Also when you flash rom flash hydro kernel because the lg stock kernel sucks I will do key switch and a couple other things and I will give out or release test build
    Also I made an s version too
  18. #18
    If you made a S version, you should remove " Tweaked for the Optimus V " :P
    And please release test in comments. xD
    Use the keylayout from the patch Nitestalkr made. Just copy the folder over in winrar, no need to copy individual files. It works for me.
  19. Thread Author  Thread Author    #19
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    They are sorta different
  20. #20
    Posts
    ROM
    Changes Daily
    Default
    Can't wait to try it out!
  21. Thread Author  Thread Author    #21
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by thewraith420 View Post
    Cool well will release build tommorow with key switch
  22. #22
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    I might just cave in and flash to ZVJ and try this out myself.
    Been needing to try a new non ICS or JB rom xD
    @Andrew, if I somehow successfully flash to ZVJ and root it, I will write out everything I did, so you could try too.
    sent from my un-dead sammich.
    Thanked by:
  23. #23
    Quote Originally Posted by nitestalkr View Post
    I believe he did it already. I believe it was him when I did it too. I don't recommend it though if your a busy person. You miss ALOT of Phone calls and messaging. It's kinda a long process.
    The patch should work on here ither way.
    Thanked by:
  24. #24
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    Well considering I currently don't have service on my phone (for the next 2 or 3 days) I have plenty of time
    And I know the patch will work, this is what it was made for, in anticipation for Optimus V ZVJ roms
    Made the patch before such a ROM was created
    Thanked by:
  25. Thread Author  Thread Author    #25
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Anyone want screenshots?????
    Or should I wait until I release
    REMEMBER PEOPLE FLASH HYDRO KERNEL OR IT WILL NOT OC AND IT WILL BE SLOW I KNOW I TRIED IT
