- 08-12-2012, 11:30 AM #326
Hey would this rom and kernal work on ZV9?
Sent from my VM670 using Android Central Forums - 08-12-2012, 11:34 AM #327
Can I use the CAI kernel on Alpha 1(because I have yet to flash Alpha 4
)? More importantly, how do I flash it? I've never flashed a kernel.
Sent from my LG-VM670 using Android Central Forums - 08-12-2012, 11:44 AM #328Thanked by:
- 08-12-2012, 11:45 AM
Thread Author #329
Flash alpha 4, then gappz, then the kernel its that easy
Sent from my LG-VM670 using Android Central ForumsThanked by: - 08-12-2012, 11:47 AM #330
- 08-12-2012, 04:15 PM #331
Re: [ROM][WIP-ALPHA4][CM10 PORT] Jelly for Optimus V
Question... why CAI kernel? Not trying to second guess you. Just curious.
I thought I read that Cold As Ice died and was merged into or became Quattrimus. If so... wouldn't that make the latest Quattrimus kernels superior? - 08-12-2012, 04:55 PM #332
- 08-12-2012, 05:07 PM
Thread Author #333
- 08-12-2012, 05:18 PM
Thread Author #334
Anyone though of using thekravens camera fixes?
Sent from my LG-VM670 using Android Central Forums - 08-12-2012, 05:49 PM #335
Hey Zakman, what did you do to get the microphone working? Over on the OptiS it doesn't work on either CM10 versions. Also, I was going to try Kraven's Camera Libs but drew said it was a kernel issue so I decided against it.
Sent from my Toshiba NB305 running Android-x86 4.0 using Android Central Forums. - 08-12-2012, 06:37 PM
Thread Author #336
- 08-12-2012, 08:51 PM #337
kernal swapped the home buttons :/
- 08-12-2012, 08:52 PM #338Thanked by:
- 08-12-2012, 11:03 PM
Thread Author #339
- 08-13-2012, 12:02 AM
Thread Author #340
Btw, to fix voicemail, go into the phone app, menu button, settings, voicemail settings, Voicemail Number and change it to your phone number.
Thanked by: - 08-13-2012, 05:55 AM #341
- 08-13-2012, 07:07 AM #342
- 08-13-2012, 07:43 AM #343
pardon my ignorance here, but if alpha 1 had both the mms and sms working perfectly...then why all not just revert back to it?
- 08-13-2012, 08:49 AM #344Optimus S patch thread
Optimus V patch thread
Optimus V Jelly Bean Support Thread
Need a new boot animation? Have a suggestion? Or a request?
Boot Animation Thread
Thanked by: - 08-13-2012, 08:50 AM #345Optimus S patch thread
Thanked by: - 08-13-2012, 09:19 AM #346
- 08-13-2012, 09:32 AM #347
- 08-13-2012, 10:39 AM #348
No it didn't. It fixed mms, yes, but it broke outgoing sms. Try it and see. Nitestalkr, thekraven quit working on his cai project for awhile and gave tdm everything. So they are kinda the same in certain things, I think.
Olan Rogers, ladies and gentlemen. Funniest video ever!!!Thanked by: - 08-13-2012, 11:36 AM #349Optimus S patch thread
Thanked by: - 08-13-2012, 12:00 PM #350
anyway, it doesn't matter about the merge between quattrimus and cai. cai's kernel was updated after thekraven started working on it again. so the kernel is different than quattrimus's. possibly better. haven't tried.
