Page 9 of 32 FirstFirst ... 6789101112 ... LastLast
Results 201 to 225 of 788
Like Tree65Likes
  1. #201
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    I am happy to report this works on the s with the patch
    Then I flashed cai kernel
    Its really smooth now
    looking for good keyboards??
    visit
  2. #202
    mcclain71's Avatar
    Posts
    ROM
    CM9.0 RC2 BobZ
    Default Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
    mms isnt working for me in alpha 3...
  3. #203
    Rudeco's Avatar
    Banned
    Posts
    Global Posts
    104 Global Posts
    Default
    Quote Originally Posted by jonny5449 View Post
    visit
    Where did u download the cai kernel?
  4. #204
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    For the last time. Fixing mms broke outgoing sms !
    Thanked by 2:
  5. #205
    mcclain71's Avatar
    Posts
    ROM
    CM9.0 RC2 BobZ
    Quote Originally Posted by andrewnelson23 View Post
    sms worked perfectly, but mms in alpha 3 wasnt working for me :/
    keep up the good work though...ur close!!!!
  6. #206
    Posts
    ROM
    Quattrimus
    in alpha 2, I fixed mms. but that broke outgoing sms. so it was unfixed.
    Thanked by:
    Zakman
  7. Thread Author  Thread Author    #207
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    App to Sd is currently being worked on by me, I'm close. The storage is read in system/storage but apps wont move yet.
  8. #208
    Quote Originally Posted by Zakman View Post
    "I had the same problem on 2 different versions of CM on 2 separate phones. This fix worked both times. Use root explorer, and make sure it is set to R/W mode (read/write). Navigate to /data/data/com.android.providers.telephony/databases/telephony.db and delete that file, then restart your phone. After the restart, you should be able to send and receive MMS messages."
    - Anyone try?
    Nope, doesn't work
  9. Thread Author  Thread Author    #209
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Anyone wanna help me put the CAI Test15 Kernel in the boot.img? I'm on windows and have no idea what im doing.
  10. #210
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    i would help but im trying to figure out how to unpack and repack boot.img's its hard and dsixda kitchen wont set up so im trying if i find anything i will letya know and if i learn i will gladly do it
    Thanked by:
    Zakman
  11. #211
    Posts
    ROM
    Quattrimus
    Yeah, you have to decompile the boot.img using dsixda's kitchen. I've never done it, and I won't have time today, but that would be a fun project.
    Thanked by:
  12. #212
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    I'm giving dsixda another shot wish me luck
    visit
    andrewnelson23 likes this.
  13. #213
    Default
    Been playing with the alpha 3 for a few hours now, SLICK!!!
    However it keeps rebooting automatically every so often, is there anything I can try to prevent this?
    Thanks
  14. #214
    Posts
    ROM
    Quattrimus
    Perhaps try overclocking. It has the kernel from quattrimus and oc ing seemed to solve reboots in quattrimus.. .
    Thanked by:
  15. Thread Author  Thread Author    #215
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Quote Originally Posted by Rudeco View Post
    http://forums.androidcentral.com/att...nel-signed.zip
    Thanked by:
  16. #216
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Dsixda failed
    Trying another thing with cygwin
    visit
  17. #217
    Posts
    ROM
    Quattrimus
    Where is it failing for you?
  18. #218
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    also, since jb is different then ics, i don't think we can use an ics kernel.
    You can use a .35 kernel on ICS. .35 is gingerbread. Nook color is still using a froyo kernel on ICS. Kernel doesn't make as much of a difference as people think it does.
    Guess whos coming back!
  19. #219
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Not sure how your having trouble with dsixda, it was probably the easiest thing I've ever done. Make sure you have a working folder or you won't be able to recompile.
  20. #220
    Thumbs up Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
    seems to have helped, thanks
  21. #221
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    In cygwin terminal I'm doing command ./menu and I get this
    Clear is not installed so the kitchen can't function properly I'm trying again
    visit
  22. #222
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    I read the kitchen read me and I'm reinstalling cygwin with neccasary packages
    visit
  23. #223
    Posts
    ROM
    Quattrimus
    Couldn't we just replace the entire boot.img?
  24. #224
    nitestalkr's Avatar
    Posts
    ROM
    Tapatalk Signature~
    Default
    I'm going to work on an app to SD-EXT script for you Zack, and you could place it into your ROM.
    Its going to be identical to the one in quattrimus, but I'm going to see if I can make it appear in the storage settings too.
    sent from my un-dead sammich.
  25. #225
    JadenBrown30's Avatar
    Posts
    ROM
    Quattrimus 4.0.4
    Default
    I'm just curious, but what made the launcher have the icons overlap things? I've never seen it before
