- 08-05-2012, 11:53 PM
Thread Author #1
[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
[BOX="WARNING!"]Hello, First I would like to tell you that I am not responsible for anything that happens to your phone by flashing this! If you have a problem, post here and we will try and help you with your issue! Thanks!
Also:
THIS IS A WORK IN PROGRESS! THERE WILL BE BUGS! If you see a bug, please report it! Thank you.[/BOX]
[BOX="Credits"]Most of this rom was an original port from drewwalton19216801 and his team! His Cm10 Port Most of the things working in this rom are from them. So thanks to them! Other things were taken from laz3r69's p500 port: So thanks to him also
[/BOX]
[BOX="Screenshots"]
[/BOX]
[BOX="INFO"]What works and what doesn't:
Working:
Calls (including microphone!)
SMS
3G data
Wi-Fi
Graphics Acceleration (for the UI)
Sensors (Accelerometor, Proximity Sensor)
GPS
Sound(Speakers and Headphones)
MMS
Bluetooth
Not working:
Camera
Google Now
Mic On Voice Search and or Google Ears.
Issues(Any help from anyone on how to fix these would be appreciated
Moving Apps to the SD Card(They move fine to the card but when you reboot they are gone)
Play store(Store does not have much on it yet, because the Android OS isn't officially released yet)(Fixed! Modded Play store added in Gapps
Battery Drain
Menu and Home Button Keys are switched.FIXED
Work Arounds:
USB Mass Storage(App Installed)
MMS: Cold As Ice working on Optimus V![/BOX]
[BOX="INFO"]To install:
1. mount phone and move Zips to the SD Card
2. Boot into Recovery
3.DO a FULL WIPE
4. format /system/
5. Flash ROM
6. Flash jb mini Gapps
7. Flash Beats Audio (Optional)
8. Reboot
[/BOX]
[BOX="Download"]Download Link:
links removed by moderator.
CM10 LIGHT Gapps(56.1mb):
CM10 Mini Gapps With Google NOW! (Read instructions below to get voice working) AND NEW GOOGLE EARS!(15mb)
Beats Audio(Optional): [/BOX]
[BOX="GNOW Voice Search"]
Google Now Gapps(VOICE SEARCH):
To install:
Flash Rom
Flash Gapps + Google NOW
Install and [/BOX]
[BOX="CHANGELOG"]08-06-2012-
Original Upload
08-08-2012-
Tiny Keyboard added (Only 2mb!) (Thanks to Andrew!) (Link for credit: )
08-12-2012
app2ext (added, Thanks to Nitestalkr and his int.d scripts)
Replaced libwmsts.so for better connection speeds
Re-uploaded Gapps
Added a YouTube app
08-15-2012
Added new Youtube apk
MMS Fixed (Hopefully)
Theme chooser added but not working atm.
08-16-2012
Alpha 5 Reuploaded
Gapps Reuploaded (Added Play store without incompatibility issues.
) (Thanks to reaper420)
08-18-2012
RIL Changes (Added libnv.so for improved RIL reliability.)
Build prop changes
New GPS file for Improved accuracy
08-20-2012
New RIL files added (Thanks to BobzHome) (WAY Better Reliability!)
Bobzhome's 4.1 Kernel Added (No Need to flash test15 anymore!) (Thanks to BobzHome)
Launcher Sizing Fixed
All audio Files fixed (When you call someone now you can hear them through to front speaker)
08-21-2012
Reuploaded with Key swap fix (Hopefully) (Thanks to Katnuk)
08-22-2012
Added working google ears to gapps
08-24-2012
Added Beats audio (Optional)
08-30-2012
Added new LIGHT Gapps with scrolling google now, voice still doesn't work, it could possibly never work. (Moded from Rashed )
[/BOX]
[BOX="Thanks!"]Special Thanks!
andrewnelson2
reaper420
and laz3r69![/BOX]
[BOX="Current"]Currently working on:
App to SD Problem.
Using a different Kernel
Fixing Home and Menu Keys
Google Now Flashable Zip[/BOX]
[BOX="Donations"]Donations are welcome but not needed for download
Thank you
[/BOX]
Thanked by 27:+ Show/Hide list of the thanked
- 08-05-2012, 11:59 PM
Thread Author #2
- 08-05-2012, 11:59 PM #3
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
First.
A few things.
1. MMS should be fairly easy to fix. Your mms workaround in the OP only fixes receiving, I think.
2. I'm glad to see you fixed mass storage with an app.
3.The mic for voice search, can you fix that by uninstalling via titanium backup and reinstalling from the Play store?
4. The Play store can be fixed, I think, by a build.prop edit that'll say that your phone is on ICS. Then you'll be able to download ICS apps, not JB apps. It's a good idea for right now, as JB app development is still VERY early.
By the way. When I tried JB a few weeks ago, it didn't have the power widget buttons in the notification bar!? Did Drew or the p500 people sync cm10 again, and that's why we have that now? What different options are there for the widget buttons?
This is almost ready for daily usage(for me
) THAT WAS FAST.
Olan Rogers, ladies and gentlemen. Funniest video ever!!!Thanked by: - 08-06-2012, 12:13 AM #4
And to think. You almost gave up.
Olan Rogers, ladies and gentlemen. Funniest video ever!!!Thanked by: - 08-06-2012, 12:15 AM
Thread Author #5
- 08-06-2012, 12:18 AM #6Olan Rogers, ladies and gentlemen. Funniest video ever!!!
- 08-06-2012, 12:19 AM #7
- 08-06-2012, 12:20 AM
Thread Author #8
- 08-06-2012, 12:22 AM #9
Ahh, I see. Well. For that, you should add in tdm's scripts that put all apps on the sd-ext anyway. We'll probably need that later, when people start putting lots of apps on their phones and start running out of space. You could pm him and ask him for permission. That might fix it.
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 08-06-2012, 12:30 AM #10
Btw, I noticed that that p500 thread was shut down. So how are you going to sync future builds?
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 08-06-2012, 12:31 AM
Thread Author #11
This isnt a sync it's a port, so Im basically going to update this build as the other one does so when the build updates I'm going to have to re-port again.
Thanked by: - 08-06-2012, 01:33 AM #12
Looks very good! Oh the keyboard doesn't start up (force closes) and can't get past the signing in to my Google Account.
Also, the USB Mass Storage popup comes up at boot up as well.
- 08-06-2012, 01:38 AM #13
I tested it out. ITS SO FAST. I love it.
The home button didn't work for me.... Tried switching out the thunderc_keypad.kl from /system/usr/keylayout with the one from quattrimus. that didn't work...
While I was switching out the thunderc_keypad.kls, I had to extract the one from quattrimus on my phone, and I noticed it extracted to /storage/sdcard0. I believe this probably happened as a result of the app that's supposed to fix usb mass storage. This could possibly be what's messing up moving apps to sd card(I don't know, just throwing out ideas).
Now, why didn't switching out the thunderc_keypad.kl's work?
I set the correct permissions and owners...
Other than that:
The browser does not work. I click on it and it closes immediately. (I'm sure another browser would work fine.
The voice search does not work, even when installed from the Play Store. (I have no idea what's up with that, but tomorrow I will logcat it.)
I called my voicemail and it didn't go to my voicemail. It went to some recording of Virgin Mobiles...?
Screen Security does not work yet.
Settings button in Notification dropdown does not work.
After holding power button and choosing to reboot into recovery, it just boots you back into CM10.
Tomorrow I will also try messing with the build.prop to see if we can get ICS apps.Last edited by andrewnelson23; 08-06-2012 at 01:50 AM.
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 08-06-2012, 01:38 AM #14
Thanked by: - 08-06-2012, 01:44 AM #15
Actually, it worked for me. So that's weird...lol
Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 08-06-2012, 01:47 AM
Thread Author #16
Thread Author #17
- 08-06-2012, 01:54 AM #18
Course I flashed gapps! xD none of those problems pertain to gapps not being installed. I'll test again tomorrow. In the meantime, other people can confirm the minor bugs in it(or perhaps disconfirm).
Went back to Quattrimus and my voicemail works fine on here.
I think tomorrow I'll try the super JB fix to see if that fixes my button issue. Also, that should fix the problem with apps disappearing after reboot.Olan Rogers, ladies and gentlemen. Funniest video ever!!! - 08-06-2012, 02:01 AM
Thread Author #19
- 08-06-2012, 02:05 AM #20
- 08-06-2012, 02:16 AM #21
I was having problems signing in to my Google account after first time setup, and I think I noticed "Google search has unfortunately stopped" popping up each time I tried to type, so I went and disabled voice typing and keyboard now works.
Also flashed jellybean super fix, and seems to be working well. sd-ext works as well too. - 08-06-2012, 03:02 AM #22
- 08-06-2012, 03:41 AM #23
I'm assuming this has the usual CyanogenMod goodies, and is less AOSP-e?
And I got permission from tdm to make a flashable zip of his 2ext scripts, I haven't gotten around to it, but expect a zip by the end of this week(or sometime during) to be made.
sent from my Zom-"Bean"(AOSP JellyBean).Last edited by nitestalkr; 08-06-2012 at 04:01 AM.
Optimus S patch thread
Optimus V patch thread
Optimus V Jelly Bean Support Thread
Need a new boot animation? Have a suggestion? Or a request?
Boot Animation Thread
Thanked by: - 08-06-2012, 07:03 AM #24Guess whos coming back!
- 08-06-2012, 07:30 AM #25
