Page 12 of 70 FirstFirst ... 9101112131415 ... LastLast
Results 276 to 300 of 1740
Like Tree8Likes
  1. #276
    Default
    Quote Originally Posted by KenDrOiD101 View Post
    has the problem with the proximity sensor on a call been fixed?
    I would have to say yes because it works perfect for me!
  2. #277
    Default
    Hey if you guys want your hotspot to work on 2.3 the app "Wireless Tethering" works very well, it's free in the Market. Quicksettings does not work anymore!
  3. #278
    Liquidplacidity's Avatar
    Posts
    ROM
    aospmod recent
    Default
    The GPS icon stays up when I'm done with the GPS, until I reboot my phone. Weird.
  4. #279
    Default
    "The GPS icon stays up when I'm done with the GPS, until I reboot my phone. Weird."
    That is weird...I just ran navigation and it turned on next to my wifi icon but then turned off when I backed out. Maybe its the app your using? It may stil be running in the background.
  5. #280
    Posts
    ROM
    aospmod recent
    Default
    Quote Originally Posted by ashton4life View Post
    Nah, it's not that. I make sure that it's not running in the background. Also, I'm using google navigation. For me, there's really no need for any other nav apps. I think i'm actually going to flash to the 0324 version. By the way, what's "vanilla" ?
  6. #281
    citizeninsane89's Avatar
    Posts
    Global Posts
    102 Global Posts
    ROM
    CyanogenMOD
    Default
    Quote Originally Posted by Liquidplacidity View Post
    Stock
  7. #282
    Posts
    ROM
    aospmod recent
    Default
    Quote Originally Posted by citizeninsane89 View Post
    Stock
    Stock? Impossible for gingerbread to be "stock" lol. I've just flashed it and it looks pretty bare. Is that what you mean?
  8. #283
    s2h2golf's Avatar
    Posts
    Global Posts
    239 Global Posts
    ROM
    2.3.4 / Stock
    Default
    Vanilla means pure Google gingerbread 2.3 OS, without any third party skins or applications. Most manufacturers skin the OS with Touchwiz (Samsung), Sense (HTC), Motoblur (Motorola), etc.
    Motorola Droid > HTC Aria > Samsung Captivate (Serendipity 7) > Virgin Mobile Optimus V (CM7) > Motorola Atrix > HTC Flyer
    Thanked by:
  9. #284
    Default
    i completely LOVE this theme. They said Gingerbread roms had horrible battery life... the battery life on this is actually GREAT. Good job, and thanks
    Will donate soon.
  10. #285
    whyaphoenix's Avatar
    Posts
    ROM
    AOSPCmod 7 2.3.3
    Default
    delete
  11. #286
    Default
    Quote Originally Posted by whyaphoenix View Post
    oh how I wish I could use this ROM... cant seem to flash clockworkmod recovery over my thunderc recovery no matter what I do...
    try typing it in the Terminal Emulator app which is in the market .. only thing is you need the codes to flash. It worked for me.
  12. #287
    Default
    Try this, go to : http://forum.androidcentral.com/opti...-features.html then download ROMtools with Optimus V drivers into your computer. (that is if you have a V) First open the ROMtools folder and make sure the image file "recovery" is "vrecovery", rename it if needed. Then run ROMtools add the drivers then flash the recovery. It's the recovery I have and it works fine. After you flash the recovery make sure you wipe data, wipe cache and wipe dalvik in the recovery menu before to flash the Rom.zip. I do everything from the phone recovery menu once its flashed in the phone.
  13. #288
    munkyvirus's Avatar
    Posts
    ROM
    Rooted Stock
    Default
    New release is out. Supposed to fix the battery. But he switched to Zeam launcher, ewww
  14. #289
    bn
    bn is offline
    bn's Avatar
    Posts
    Default
    Is battery usage any better with Zeam than it is with LauncherPro? I'm not sure I see any difference.
  15. #290
    Default
    looks great, only feature i miss from the 3/22 is being able to turn the phone sideways and have the screen rotate on the home menu and 1st screen, wifi and 3g seem to be speeding up to
  16. #291
    Default
    my andriod version on about phone screen says:
    Android version 2.3.3, one on the 1st post says 2.3.2 anyone elses say this? now off to flash prl to see if i can get faster 3g
  17. Thread Author  Thread Author    #292
    Default
    new gapps/rom/cwm in OP.
    no the cwm is not 100% needed to flash this, but no support for other recovery.imgs. Xionia CWM works fine.
  18. #293
    Nit3H8wk's Avatar
    Posts
    ROM
    Harmonia
    Default
    What was changed in the 3/25 build that was just posted. I am having trouble with the headset that came with my optimus v. I can hear from it but no one can hear me. This problem does not exist with any of the 2.2 roms. Also the stock headset is not bluetooth. Also the last build i tried was the 3/22 and the games and os overall seem a bit laggy and less responsive than stock.
  19. #294
    Nit3H8wk's Avatar
    Posts
    ROM
    Harmonia
    Default
    Ok i found a changelog for folks who want to see it.
  20. #295
    Default
    Do i flash the image as recovery in terminal emulator? Any advantages to it over clockwork recovery?
  21. #296
    Default
    I just got the 24 build set up like I want it and it's fantastic. On battery for over 2 hours with some Pandora steaming, texting and web surfing, with 3g never off and I'm still at 100%. Either I'm doing something wrong or the battery life is amazing.
    Only annoying thing now is the Swype problems.
    Keep up the amazing work.
  22. #297
    Default
    I have a newbie question....I was wondering if I would like to update my phone with the updated ROMS whats the best way to do this? Can I just flash over mine and not wipe anything? Do I need to reinstall everything? Do I just install the new zip or update? Thanks
  23. #298
    Default
    Quote Originally Posted by duke_4386 View Post
    What? 2 hours of music and surfing and still 100%? How can that be? Can you confirm that? If that is true you need to link a copy of your backup for me bro! lol
    Ya Swype has issues, you have to keep changing from the android to the swype keyboard when ever it stops functioning or just get a nother swype type app.
  24. #299
    Default
    Have you guys tried slideit keyboard? I like it better than swype.
  25. #300
    Default
    Oh, sorry, some, not 2 hours of continuous streaming. A bit over half an hour of streaming on the way to work.
    Now I've done some more browsing and downloaded the new google apps and new Clocthekwork Mod and I'm down to 88% battery. I'd narrowly get this on the stock ROM even with JuiceDefender.
    Thanked by:
B
