Page 8 of 70 FirstFirst ... 567891011 ... LastLast
Results 176 to 200 of 1740
Like Tree8Likes
  1. #176
    ThaLuser's Avatar
    Posts
    Global Posts
    19 Global Posts
    Default
    I think I found a solution to the MMS problem. GO SMS in the Market lets you manually input the MMS settings. I found the configuration for VM in res/xml/hidden_settings.xml in the stock ROMs Mms.apk. To configure MMS, perform the following steps: Disable notifications in the default messaging app. Launch GO SMS, go to Settings, MMS Related, and check Fill APN configuration manually. Enter the follow configuration:
    MMSC:
    MMS PROXY: 205.239.233.136
    MMS PORT: 8088
    Let me know if this works. I'll test this later on when I have time to flash this ROM.
  2. #177
    Default
    Quote Originally Posted by ThaLuser View Post
    MMSC:
    MMS PORT: 8088
    THAT will be awesome if that works!!! I am not running the rom right now, so I can't test it.
  3. #178
    Liquidplacidity's Avatar
    Posts
    ROM
    aospmod recent
    Default
    MMSC:
    MMS PORT: 8088
    Testing right now.
  4. #179
    Default
    Please god let it be the solution
    Sent from my VM670 using Tapatalk
  5. #180
    Posts
    ROM
    aospmod recent
    Default
    Doesn't work. Only sending them work. Still shows up as 99999999 in go sms.
  6. #181
    Default
    Darn it!!!
  7. #182
    Default
    Does the Samsung intercept also use the weird mms system?
    Maybe we could change the mms user agent to intercept or blackberry and receive a nice standard mms
  8. #183
    Posts
    ROM
    aospmod recent
    Default
    I'll actually try to figure out a way when I get home. It's probably something really stupid that none of us are seeing.lol
  9. #184
    Default
    Quote Originally Posted by Liquidplacidity View Post
    Can't we just take the MMS.apk from the stock rom, and use it? I don't know anything about this, so I am just asking
  10. #185
    Posts
    ROM
    aospmod recent
    Default
    Quote Originally Posted by idbl_fanatic View Post
    Nope. I already tried doing that. It didn't seem to do anything at all actually. ill try looking through the framework and see if I can find anything.
  11. #186
    nickmiller71's Avatar
    Posts
    Global Posts
    239 Global Posts
    ROM
    Harmonia 2, Mango
    Default
    Does anyone know when the next update for this rom will be?
  12. #187
    Default
    Quote Originally Posted by sportsinger75 View Post
    Yes, the author said he'll release it right before midnight on 03/31/2011.
  13. #188
    JerryScript's Avatar
    Daydream Believer
    Posts
    ROM
    BACKside-IHO
    Default
    Great ROM, thanks to the team that put this package together!
    I do get an occaisional freeze, but it may be due to overclocking (just over 800). Otherwise everything seems smooth.
    Apps appear more frequently in AppKiller listings, not sure yet if I need to change a sync setting or something.
    Thanks again, looking forward to future goodies!
  14. #189
    icemank121's Avatar
    Posts
    Global Posts
    77 Global Posts
    ROM
    CyanogenMod 7
    Default
    The Intercept, or really any VM phone, has the same issue. VM has special code in the frameworks that decode the odd MMS format. The only way to get incoming working on a non-VM based rom would be to port the code over to CyanogenMod source. This is a lot of work, but it does sound like people are working on it.
  15. #190
    Default
    Quote Originally Posted by icemank121 View Post
    That's what I feared. All part of being on a MVNO I guess..
    We should get the emails to some lg devs and coax them into some cooperation haha
  16. #191
    Posts
    Global Posts
    239 Global Posts
    ROM
    Harmonia 2, Mango
    Default
    Quote Originally Posted by mmarz View Post
    Fantastic. I really love this rom, especially with dat2ext enabled.
    Sent from my LG Optimus V using Tapatalk
  17. #192
    Default possible fix for proximity issue
    The proximity issue while on a call was driving me nuts, and I almost went back to stock...then I found this.
    http://forum.androidcentral.com/lg-o...ghtly-135.html
    This seemed to fixed my proximity issue, and thought I would pass it along
    Hope it works for everyone else.
  18. #193
    Default
    You may want to mark that day down on the calendar.
  19. #194
    Default
    Quote Originally Posted by speedy3k View Post
    And for us that don't know how to edit the build.prop file?
  20. #195
    Default
    I used textpad.
  21. #196
    Default
    Quote Originally Posted by simon.ponder View Post
    Original: (Thanks for pointing that out shortyjacobs)
    ro.lge.proximity.delay=100
    What I changed it to:
    ro.lge.proximity.delay=25
    This sounds like it changes the blinking rate of the IR Led. If anyone has a digital camera (digital cameras can see IR), try recording the area immediately left of the "Virgin mobile" logo while making a call at different proximity delay values, and then compare it to a recording of the stock/rodimus rom. You'll see a very faint light blinking. I think it is a matter of the sensor missing the moment when your head pulls away. If we can match the blinking rate to the value used in the stock rom, I think it'll solve the problem. In the Scott Pilgrim thread, the person that found the solution reports that it is not 100% solved yet. I think if the LED blinks too fast, it will either overwhelm the sensor or needlessly use up battery, and if it blinks too slow, it'll miss your head moving away. If I had a camera on me I would test it out, but this phone is my only camera for now.
  22. #197
    Default
    There may be something to this "ro.lge.proximity.delay = X" thing. In my /system/build.prop file I didn't even have an entry for ro.lge.proximity.delay. So I added "ro.lge.proximity.delay = 100" to just experiment.
    I have a feeling that it isn't being set correctly without that entry. Will update with how things go, but in a preliminary test call the proximity sensor worked perfectly.
    Thanked by:
    Chef_
  23. #198
    Default
    Nice, worked perfectly for me. Didn't have an entry for ro.lge.proximity.delay = 100 at all, do now!
  24. #199
    Gutterball's Avatar
    Posts
    ROM
    RodimusROM v1.2.2 ║
    Default
    are you sure I heard its coming out a minute after midnight not before?
  25. #200
    Gutterball's Avatar
    Posts
    ROM
    RodimusROM v1.2.2 ║
    Default
    aosp
    Yesterday, 05:59 PM
    "should have a new one up for you guys sometime today stay tuned"
    Thats a quote from the original xda thread from the creator of this rom. Though it still hasnt been updated there yet either but sounds like it should be soon.
