- 02-21-2011, 09:46 AM
Thread Author #1
[ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
MD5: 4cbe712c0bde778fb7f2d32d32b57dd8
aospCMod-OV-20110531-signed.zip available on Rom Manager under "Download Rom"
MD5: e75e92d259c675b9dfd5113bd1cd0939
aospCMod from Optimus V to Optimus S .zips
HOWTO
ROM/Kernel DEV: aospPC via ADB:
adb logcat > /path/logcat.txt
ctrl+c
Phone via Terminal emulator:
logcat > /sdcard/logcat.txt
press the trackball (for ctrl) and c to end the output.
I'm just sharing the rom link with android central.
Thanked by 48:+ Show/Hide list of the thanked -
00damedash, alex.lgopv1550, shindig, Arliman, aznkaz, beepFTW, Billzilla, cachedfailure, daveh2676, dazedabyss, devgru82, dlinderaz, ejlmd, Etegral, FLDataTeK, gater, Godbilla, Gutterball, inmenzo27, JerryScript, joryb, KemikalElite, keystonep1mz, KidFr3sH, Kiernon, Kreatur3, LeslieAnn, liquidmass, Mirth, noob47, phreak311, pre, MachPrimeRib, r00t, RavenSEAL, shakefu, sixit, snobro, nickmiller71, staticmaal, takehull, tmartin91, Toxic_Intruder, venkyandroid, wired57, ykameron, zedorda, zeffyp
- 02-21-2011, 09:58 AM #2
nice!
An what are the differences between this and Zephie's work with Xionia and CM7? - 02-21-2011, 10:12 AM
Thread Author #3
- 02-21-2011, 10:44 AM #4
Does WiFi tethering work with this?
I am running RevolutionRed's ROM + Kernel package and WiFi tethering doesn't work with it.
Would love to try this out if it can get me that functionality again.
Thanks - 02-21-2011, 10:46 AM
Thread Author #5
- 02-21-2011, 12:01 PM #6
testing now, but seems to freeze up on the cyanogen boot screen. Wiped cache and davalik cache. Noob here so it might be my fault.
- 02-21-2011, 12:05 PM #7
- 02-21-2011, 12:14 PM #8
Yeah i used all files included in the post he linked to at xda.
edit: forgot to factory reset it/wipe things under the mounts and storage format option.
Booted fine now. My bad, beginner mistake.
will report in later on how the build is.Last edited by danhalen; 02-21-2011 at 12:22 PM.
- 02-21-2011, 12:17 PM #9
This is awesome blazing fast and super smooth!!!!
- 02-21-2011, 01:15 PM #10Thanked by:
- 02-21-2011, 01:20 PM #11
Working great so far, just remember to go to Call Settings, change voicemail settings from *86 to phone number and check "Always Use Proximity" to fix screen staying black during call when moved from face.
- 02-21-2011, 01:27 PM #12
I'm having an issue with the headset quality when I'm listening to music and what not...anyone else experiencing this? Does anyone know if there is an easy fix? Thanks a lot.
Update - I have this issue with all the Gingerbread ROMs out there...Last edited by sportsinger75; 02-21-2011 at 01:59 PM.
- 02-21-2011, 02:20 PM #13
flashed to CWM and flashed rom easily, phone seems to be overheating now while phones on.
- 02-21-2011, 02:44 PM #14
can anyone confirm if MMS is working?
- 02-21-2011, 02:50 PM #15
When I receive texts it comes as "From 99999999" and msg is in chinese
- 02-21-2011, 03:05 PM #16
Trouble Flashing CWM
I used these commands and get an error saying "No more space".
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
flash_image recovery /sdcard/recovery-clockwork-3.0.0.6-ov-20110220.img
reboot recovery
When it reboots to recovery, there is a Blue Fastboot screen and no recovery. Anyone else have a better method of getting CWM going. Im coming from RA-thunderc. - 02-21-2011, 03:12 PM #17
- 02-21-2011, 03:21 PM #18
- 02-21-2011, 03:42 PM #19
Car Mode doesn't work for me either (same issue - goes back to home screen). Otherwise, pretty cool to have 2.3!
I'm debating whether I am going to overclock with SetCPU. Phone does feel a bit warm so maybe I will use SetCPU to throttle down the CPU at idle.
Thanks! - 02-21-2011, 04:41 PM #20
can anybody point to the right direction to get the kernel for this rom im kinda lost
- 02-21-2011, 06:16 PM #21
- 02-21-2011, 06:32 PM #22
Is there a way to switch to the regular Gingerbread launcher? I am not a fan of ADW. I would post this on xda but apparently I'm not smart enough to post.
- 02-21-2011, 09:28 PM #23
- 02-21-2011, 09:49 PM #24
- 02-21-2011, 10:23 PM #25
I see the connection as AP Android and I can connect to it, but I can't access any sites or anything through it. It tells me something like limited Internet connection. However, I am able to use 3G data on the phone itself.
How would I go about to fix this problem?
