Help with charging times (bumblebee 2.4)
cybermaniak
77
Hey guys I?m using Bumblebee 2.4 and its?s taking a lot time to charge.
I have been watching carefully and 1 percent is taking around 6 minutes, that would be 600 minutes to charge a 0-100% = 10 hours ....
It?s this normal ??
when I was on stock rom (rooted only) it didn?t take that long...
I have 3 cables and with all three is the same..
Any clue ?
Kreatur3
660
40
It?s this normal ??
Any clue ?
Either your battery is crap or you need to recalibrate your battery.
israelsalinas14
188
3
I'm on bumblebee 2.4 and it only takes about 2.5 hours to fully charge when I dont use it. But when I use it as its charging, it can take really long.
Kreatur3
660
40
This problem only started when I did the rom change.. How to recalibrate the battery ?
Go into recovery and wipe your battery stats, should be under advanced where wiping dalvik is.
I haven't used bb2.4 since I started testing ath3nos but it never took nearly that long to charge my battery.
cybermaniak
77
Thanks.. and that could be done either if its not fully charged ? only plugged to the wall ?
cybermaniak
77
Found some instrucctions... is this correct ?
Charge to 100%
Clean batterystats (from recovery mode)
use the phone until the battery is dead (the phone turn off)
and charge again.. (with out touching the phone)
Kreatur3
660
40
Charge to 100%
Yeah, I would just do those steps and then see how it goes.
Could also be a problem with the install you did so if that doesn't help I would try doing a fresh flash and remember to wipe everything.
