Results 1 to 16 of 16
    Unhappy Need help removing CyanogenMod from LG Optimus V
    I've been looking all over the internet and this site but I haven't found a definitive solution to my problem. I just received a brand new LG Optimus V that was already running on CyanogenMod/ClockWorkMod. Unfortunately, I have no way to activate the phone on my Virgin Mobile account since the UI is different, making it pretty impossible to activate it. If anyone can direct me to either proper directions for getting the phone back to the original stock or a way to activate it while still being rooted, I'd greatly appreciate it.
    Thank you.
    (sorry ahead of time if I really did miss the proper posts for finding the solution)
  2. #2
    Kreatur3's Avatar
    Posts
    ROM
    MIUI
    Default Re: Need help removing CyanogenMod from LG Optimus V
    Flashing to a froyo rom will give you the ability to use the activate option. Not sure which roms support using clockworkmod but I know that bumblebee does. You could also flash the xionia recovery which supports any and all roms we have available and then flash any froyo rom.
    It takes less time to hit thanks than it does to type it out...
    I dig being flamed so FLAME ON!
    Thanked by:
    Quote Originally Posted by Kreatur3 View Post
    Thanks for the info. Only thing is I don't know how to do ANY of that. So I need to find a froyo rom on here to get back to my active point. Ok. Gonna search. Still very confused but Thank you
  4. #4
    Quote Originally Posted by AriaOfSolace View Post
    ok go grab
    romTools which is HERE---->http://forums.androidcentral.com/opt...-features.html
    flash xionia cwma 12518.4 recovery using romtools
    then grab a popular OV rom like:
    bumblebee ---> http://forums.androidcentral.com/opt...25-2011-a.html
    or Harmonia ---> http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/78956-romfa-harmonia-1-3-1-aphrodite-picasticks-16july11-2-2-bits.html
    put them in the root of ur sd card use romtools to get into the recovery
    when u get into the recovery u wipe EVERYTHING
    select wipe data/cache
    select wipe cache partition (i do it just cause)
    go down to the mounts & storage
    select format SYSTEM, DATA, CACHE
    then u press back then go 2 advanced then select wipe dalvik cache
    press back select install zip from sdcard
    then select choose zip from sd
    then select the froyo rom u downloaded sit back & let magic happen when its done go back 2 the reboot system now. (the 1st time flashing a rom may take like 3-5 min 2 load up) but when ur rom loads up hit activate then u should be done
  5. #5
    Default
    What he said but wipe system too
  6. #6
    huchman's Avatar
    Posts
    ROM
    Harmonia 1.2
    So ##virgin# won't work with cm7? Or just the activate app itself?
  7. #7
    Kreatur3's Avatar
    Posts
    ROM
    MIUI
    Quote Originally Posted by huchman View Post
    No.
  8. Thread Author  Thread Author    #8
    I tried but it didnt work. I called them and they did their best to help me, but you need to be on the froyo interface to activate the phone. you can do whatever after that, but it needs to be activated first before flashing/rooting... I guess. :/
    Quote Originally Posted by 00damedash View Post
    ok go grab
    THANK YOU SO MUCH. Ok, I'm just a little lost on some parts but I think I'll be able to do it. If I get screwed up or lost, I'll be back. THANK YOU AGAIN FOR THE HELP
  10. #10
    I wanted to bring my Optimus V back to stock as well, and here is a link I found that worked great for me:
    In your case, all you want to do is flashing the stock ROM. Download link is at the bottom.
  11. Thread Author  Thread Author    #11
    IT WORKED. Holy crap this is awesome
  12. #12
    no prob!!!!
  13. #13
    This may sound stupid, but how do Extract the contents of ov-stock-rom.zip to /clockworkmod/backup/ on your SD Card
  14. #14
    anthonycr's Avatar
    Themer. You've seen them
    Posts
    By using a file manager. You don't need to unzip anything.
  15. #15
    Exclamation Re: Need help removing CyanogenMod from LG Optimus V
    anyway to recover the msid network number from the original seller in the phone or their phone number as virgin needs it to activate this phone to my account, ive tried contacting seller to no avail, goin back to stock on my cy 7 rom now
  16. #16
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Quote Originally Posted by tketch35 View Post
    More than likely, the original seller sold it because he doesn't know the MSID because he was messing around with stuff or something and screwed it up. Unroot the phone, go to a VM retailer, ask them to activate it. Or call VM's customer support with another phone.
