Disclaimer:I am not responsible if you break,brick,hump,throw against wall or any other action to do to your phone. By using this bootanimation you agree anything that happens is your own noobtastic fault. Any attempts at blaming me for anything other than this being fantastic will result in you being pointed and laughed at.
New files uploaded.
Sized down to fit better.
Added a grey background.
If you like the while background use the one that says while in the name. Once you download it rename it to bootanimation.
In adb type adb shell bootanimation.
To add the sound use these instructions.
Unzip the file first.
http://dl.dropbox.com/u/10373328/bootsnd.sh
New files uploaded.
You can also preview your bootanimation before rebooting.Root Explorer method:
1. Rename your boot animation to bootanimation
2. Put it on your SD card
3. Open Root Explorer and copy bootanimation.zip to /system/media. This will replace the existing boot animation
4. Reboot your phone
ADB method:
1. Make sure you have downloaded android sdk
2. Put android sdk in C:\
3. Set the directory of command prompt to C:\android-sdk-windows\platform-tools. Click here for a video tutorial.
4. Rename your boot animation to bootanimation and put it in C:\android-sdk-windows\platform-tools
5. Open cmd
6. Type in order:
-adb remount
-adb push bootanimation.zip /system/media/bootanimation.zip
-adb reboot
Originally Posted by hockeyfamily737
0. It's recommended to do a nandroid backup first!
1. Download the "bootsnd.sh" file and put it on the root of your sd card.
2. Download the "android_audio.mp3" file and using root explorer copy it to /system/media
3. Open Terminal Emulator and type the following commands using the stock keyboard. Press enter after each line:
su
cd /sdcard
sh
sh bootsnd.sh
reboot
4. As the device boots up you will be greeted by the "Dolby THX" test sound heard before movies. You are now free to replace the android_audio.mp3 file in /system/media with any .mp3 file you like as long as you rename it to "android_audio.mp3"
5. DO NOT ATTEMPT TO OUTSMART THESE DIRECTIONS OR YOU WILL BE RESTORING YOUR NANDROID BACKUP!
6. Enjoy
