Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Like Tree2Likes
    Unhappy Terrible battery life on BACKside rom?
    I've been using this rom for a while, and have been getting terrible battery life out of it, at least 10 percent drain per hour, even using JuiceDefender. I used Harmonia before this, and got excellent battery life out of it, only about 2 percent drain while idle with 3g/wifi on constantly. On both roms I was over clocked 320/806. Help is greatly appreciated.
  2. #2
    Default Re: Terrible battery life on BACKside rom?
    I also got really poor battery life on backside. I switched back to bumblebee. You should keep your clock speeds close to each other. Use 806-806 for the best battery life you can get off this phone.
  3. #3
    Default
    Quote Originally Posted by israelsalinas14 View Post
    Yeah if you want to kill your cpu go ahead
    - Sent from my LG Optimus V using Tapatalk
    Thanks for the input.
  5. #5
    my battery life is only slightly slightly lower than when I was on AOSPCM7.
    but i wouldnt trade a gingerbread rom for a froyo rom ever, ever again.
    I get a consistant 7 to 9 hours of use before my battery is dead. but im the kind of person whos phone is pretty much on 24/7 if im not browsing the internet, im listening to music (phone is my ipod) or watching youtube or netflix. or texting like mad. seriously my phone never stays idle for more than 20 minutes. its being used like crazy.
  6. #6
    Whyzor's Avatar
    Posts
    Carrier
    HyperNonSense ICS
    There could be an app service running in the background that drains the battery. I keep mine pretty lightweight (no extra apps installed & services running). With 3G, Wifi, GPS, BT all off, and just cell signal on, I get less than 1%/hour drain. Turning on 3G and using it drains a bit quicker. but still pretty good. Maybe you'll have to try to re-wipe (using CWM recovery since it does more complete wipe), format all partitions EXCEPT /sdcard, and reflash.
    Hmm... But it makes me wonder why this kind of drain happens on gingerbread and not froyo?
  8. #8
    LeslieAnn's Avatar
    AC Forums Android Developer
    Posts
    Carrier
    Harmonia 3
    Quote Originally Posted by funnybrains12 View Post
    Froyo was horrible when it came out as well if you remember.
    The latest Froyo builds have gone leaps and bounds over stock Froyo, but it took a while. The problem with GB is we don't have the stock driver to work from in some cases, it's newer, and can use more processing power. No one really knows how much it took to get Harmonia to do what it does with a battery.
  9. #9
    I have actually noticed not much of a drain when my phone is idle but it still sucks the battery bad when I'm watching movies and what ever
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by LeslieAnn View Post
    Well, I'm glad we have devs like you who know what to do. Thank you and all the other devs for all that you do!
  11. #11
    Eollie's Avatar
    Posts
    Global Posts
    1,575 Global Posts
    Carrier
    Some arrogant a-holes
    How long have you had backside installed? A true test of how the battery life is, give the rom at minimum three days.Be sure to wipe battery stats and do a complete chare/discharge/recharge.
    NO NO NO NO NO.
    Its been proven this is circumstantial.
    Keeping the phone ramped to max will only harm your battery and cpu.
    Does your phone get hot running like this? I dont think anybody has reported it not getting hot. My phone would sit idle for hours and I would pick it up and be hot to touch.
  12. #12
    JerryScript's Avatar
    Daydream Believer
    Posts
    Carrier
    Victorious
    Here is the type of battery life you should be getting on IHO:
    pre likes this.
  13. #13
    Whyzor's Avatar
    Posts
    Carrier
    HyperNonSense ICS
    Here's a couple of recent usage graphs for me:
    bdieu17 and JerryScript like this.
  14. #14
    How much usage is that with tho? i wish i could do even half that but i am constantly on my phone alot and i can drain a battery quick
  15. #15
    Whyzor's Avatar
    Posts
    Carrier
    HyperNonSense ICS
    it's mostly checking battery status, a few quick calls, some web over 3G, and text messages. Light use probably.
  16. #16
    LeslieAnn's Avatar
    Posts
    Carrier
    Harmonia 3
    I only pretend like I do.
  17. #17
    Other than a couple of 6 hour stints in an area where I had next to no reception, I get about equal battery life with BACKside as I do with Harmonia. 480/806, ondemand.
  18. #18
    Whyzor's Avatar
    Posts
    Carrier
    HyperNonSense ICS
    Quote Originally Posted by Sean OGorman View Post
    I'm not surprised. I get less than 1%/hour drain when idling on this ROM. That comes close to the maximum theoretical standby time of ~100 hours researched by mmarz in his battery/ROM comparison thread.
  19. #19
    Here is my battery stats so far on backside i only run 5 widgets and a live wallpaper in the background idle is awesome but i'm looking for longevity when i use it i'm just playing games or surfing the net i can burn a battery in about 6 hours if i'm streaming videos i can do it quicker. :/ Bumble Bee was better but its not as fun as having freeking gingerbread! I love it when my cheap prepaid phone is more capable than the expensive ones everyone else has. Edit* 5 widgets a live wallpaper and just 3g and clock speeds of 408-764 for the norm.
  20. #20
    Eollie's Avatar
    Posts
    Global Posts
    1,575 Global Posts
    Carrier
    Quote Originally Posted by wagonburner View Post
    Truthfully 6 hours is pretty awesome. We will probably never be able to completely perform on GB like Froyo. Probably the best advise is to keep a spare battery. blarf has said that is unacceptable but with what people want to do with this phone its the best solution.
  21. #21
    Here is what I have today:
    I don't know why it cut off the first few hours of the day, it has been unplugged from 100% for more like 7 1/2 hours.
    JerryScript likes this.
  22. #22
    I don't want a spare battery to have to carry but I think the stock battery is awfully small I am thinking about getting that double size one with the big battery panel
  23. #23
    Blam-o
  24. Thread Author  Thread Author    #24
    Any special settings you use to get these kinds of results from your battery? Mine lasts 10 hours tops.
  25. #25
    Eh, just be mindful of what you have running in the background. Facebook and Twitter only refresh every 4 hrs (everything else, including all Google apps are autosynced), I make sure to shut off that god-awful Facebook chat when I boot, but leave Google Talk running in the background at all times. Processor is set at 480/806 on-demand.
    To be fair, normally I get 14-18 hours of life, but the car I just purchased doesn't have an auxiliary input, so I'm not streaming music on the drive to and from work right now. That alone can kill between 5-10% per hour, depending on the source. Poor network reception doesn't help either, I was in rural Ohio for Indy cars over the weekend, and was only getting 6 hours out of a charge, which was comparable to what my friend and my brother were getting with their phones (an iPhone 3GS and a Pre).
    notown likes this.
Tags for this Thread
