isssacbourne
alright man, i definitely think we're almost there. i flashed that recovery zip in clockworkmod, and then rebooted recovery and what happened was, it turned off, came back on, and then the new recovery loaded up but instead of displaying recovery options/etc, it automatically said:
Android Recovery
Do not pull out battery!
...formatting data
...formatting cache
...factory reset
and then it loads up CM7. so i was like huh? phone booted up fine (thank god), and then i was curious why the recovery hadn't booted up and gone straight to the rom. so i rebooted into recovery and the same thing as above happens. and not only just when booting into recovery, every time you turn the phone on and off. yeah....lol.
i appreciate all the help man.
Android Recovery
...formatting data
...formatting cache
...factory reset
