Custom recovery help
theguz91
I was using the sticky to get my custom recovery so I can install a rom.
It's rooted and all that, but the recovery flash is not working. I cannot get adb to work at all, so I used the terminal emulator.
I typed this in.
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
flash_image recovery /sdcard/recovery-thunderc-v-1.2.0-GNM.img
reboot recovery
This is what I got back.
# mtdblock5: not found
# cannot create /system/bin: is a directory
# flash_image: not found
# Unable to chmod /flash_image: No such file or directory
# Usage: mount [-r] [-w] [-o options] [-t type] device directory
Anyone have an idea on what's going on?
Thanks
watskyhotsky
899
115
flash_image is a actual file android uses to flash that image over the old recovery.
without it, it cant.
thats why it says flash_image not found.
youd need to place it in its correct place in the directory then try all those commands again.
d-fitzpatrick
24
4
what rooting method did you use?
what did you download and/or instal prior to entering the commands?
from my limited experience: if you ever enter code and don't get back the results you expect, Stop. if the first line of code if off it's just ganna get worse.
AmeliaRodriguez
