Hi, i had removed my sd card to do make a partition using my PC, and i'm not sure what happened, but after I ejected it, my phone said "Blank SD Card". after completing the partition on my PC (everything seemed to go fine), i put the SD card back in and now my OV won't recognize it. when in the phone, the "mount sd card" in settings is grayed out, but if i remove it, the phone will say "blank SD card" again.
any help? i made a back up of my sd card on my pc, so if i need to format it, it's not a huge deal.
thanks in advance for any help.
