Clockwork Mod Recovery help PLEASE!
EpicSlade2013
Ok i accidently updated my clockwork mod on my optimus v to 3.2.0.1 and no im getting the amend scripting error when trying to flash a .zip with rom manager is there any way to downgrade back down to 2.5.0.7 or whatever there was before the scripting problem?.?
What are you trying to flash? If it doesn't work with the latest version of CWM I'd say it's relevant to bring the ROM / whatever else you're trying to flash into question.
sounds like you're trying to flash an old rom.
you can use xionia cwma to flash amend or edify scripted zip files, maybe try that one instead of cwm. It's a fairly long time since cwm was updated to edify scripting, it might take some digging to find a release that old.
or you could flash a newer rom, most everything around now uses edify scripting.
kctraci1
