Firstly, if my understanding of the way the battery charges is correct, when you reset the battery stats, the phone thinks it's at full charge. Because I did this when changing roms not realizing this, I'm afraid I may not be getting the best use of my battery. I understand that to fix this, you can just turn off the phone and let it get a good full charge & THEN reset the battery stats. Since I'm running the IHO CM7, I can't really turn off the phone & don't have a spare or an external charger to do this.
If this IS in fact the case, I guess I need to go back to a stock system temporarily to fix this.
There are files available from How to: Return your Optimus V to Stock(Tested working) to do this.
I guess I don't want to screw anything up (aka brick) by doing something stupid.
Can I just restore my nandroid backup & then the image from the above link for the 'stock recovery'?
Remember the only purpose is for battery charging. I looked for a post discussing this but couldn't find anything. As a side note, I got this phone about a week ago and have since tried 2 roms, 3 recoveries, am using the Darktremor A2SD, got the MSL and change PRL. I absolutely LOVE this phone. I also got the force closes from installing the swype 3.0 beta. Funny, as the IHO CM7 rom didn't have it but in any case had to extract from the 1st NAND, change some settings in a init.d file, I think & was good to go.. Sorry for going off topic.
