- 02-06-2012, 07:11 PM
Thread Author #1
- 02-06-2012, 07:49 PM #2
Re: What is the best ROM to flash on an Optimus V?
I PM'ed you. And all the roms have equal risk, which is no risk if you do it right.
- 02-06-2012, 07:51 PM #3
Somebody posted somewhere, that this phone is almost Un-Brickable. So many ways to un-brick, it's marvelous. :P
- 02-06-2012, 08:07 PM #4
The only roms you should focus on really are IHO and Harmonia (which has 2 versions, IHO Gingerbread or stock Froyo) and all of them work on all phones.
There are three rules to never bricking your phone.
1. NEVER do a factory reset from anywhere except recover. NEVER, EVER, EVER.
2. Always backup from recovery before and after you flash anything.This is called a Nandroid backup.
3. And last, but not least, when you flash, do only a rom or a recovery, never both at the same time. Do them one at a time, make sure one works before you mess with the other and it is pretty much impossible to brick the phone because each serves as a backup to the other.Last edited by LeslieAnn; 02-06-2012 at 09:00 PM.
Harmonia Developer for Optimus V, Optimus Elite, One V, Evo V, Evo Shift, Evo V
Donate here if you feel inclined to brighten my day. - 02-07-2012, 12:03 AM #5
And do NOT use ROM Manager with this phone!
Thanked by: - 02-07-2012, 12:12 AM #6
also to be safe use terminal emulator to switch/put a recovery known to work on the LG optimus v 2.2.1 or 2.2.2
- 02-07-2012, 07:00 AM #7
- 02-07-2012, 10:07 AM #8
yes that's true but with 3 clicks you could brick your phone, it its a bad download .......
- 02-07-2012, 03:32 PM #9
- 02-07-2012, 03:52 PM #10
- 02-07-2012, 04:12 PM #11
The best method is how ever you feel comfortable doing it. There is a chance for problems either way. Remember tho flashimagegui is not compatible on all phones so getting use to the commands is never bad.
Thanked by: - 02-07-2012, 05:10 PM #12
- 02-07-2012, 05:28 PM #13
Actually, doing i in recovery is MUCH safer.
If it's a bad image it simply will not install, usually. This is true for either method, however you will get a notice in terminal. As for typos, it will either work, or it will not. If you misspell anything, it will simply error out and not flash anything.
So far dead heat right?
Flashgui works... For now. What happens on the next update? The terminal method is foolproof, it ALWAYS works, unless there is something wrong, and then it simply will not. There is no risk, no fear of someone else changing something.
You guys sometimes may think doing some of this the old way is silly, but my phone is older, been flashed more and done things you haven't even dreamed of, yet still runs fine, and it is because of doing this stuff the right way as opposed to the easy way is why.
Donate here if you feel inclined to brighten my day. - 02-10-2012, 11:09 PM #14
- 02-10-2012, 11:16 PM #15
The question is moot. There are benefits to both.
As for the threads author, I assume she is gone, because she just wanted to install harmonia 2 so I spent a couple hours guiding her through the process so that now that its flashed successfully, I don't think she really needs the question answered. - 02-10-2012, 11:28 PM #16
- 02-16-2012, 01:31 AM #17
Well I am definitely new to this and am wanting a sweet rom to put on my lg optimus phone. I want to get rid of all the crap like maps airg and junk. can someone do like a simple walkthrough on exactly what i should be doing in simple steps? Id appreciate it very much.
- 02-16-2012, 02:16 AM #18
- 02-16-2012, 09:14 AM #19
- 02-16-2012, 09:16 AM #20
- 02-16-2012, 09:46 AM #21
What are you talking about... between froyo, gingerbread, and now ICS (taddaaa!!) There are over a dozeb different roms to flash. If you think a dozen (or more) isn't enough, I don't think youl ever be satisfied.
You can find at least 6 current roms for the OV on the github page. - 02-16-2012, 03:40 PM #22
There are several OV roms, but most are extremely outdated and will use up a lot of space on updates, some don't work with newer phones either.
And for Harmonia 2, it is an IHO rom.
Donate here if you feel inclined to brighten my day. - 02-17-2012, 09:25 PM #23
- 02-17-2012, 09:27 PM #24
- 02-18-2012, 10:03 AM #25
Reply
