1. itsrayray's Avatar
    Dude at work wanted to put iho on his phone. So i showed him the ov forums and told him make sure to read.
    Hell tells me that he downloaded rom manager and he loaded the recovery from rom manager.
    I told him not to use it as it will brick his phone. So i come back to work and he said he went ahead and downloaded a free rom via rom manager and bricked it using it.
    Soo my ? To whoever is what would be the first step to get his phone functioning again?
    Sent from your mom's phone.
    02-16-2012 05:58 PM
  2. ehoser's Avatar
    Can we assume that since he missed the numerous "DON'T USE ROM MANAGER!" warnings that he also missed the "ALWAYS MAKE A BACKUP BEFORE YOU FLASH A ROM" warnings too?
    02-16-2012 06:23 PM
  3. itsrayray's Avatar
    yes. Lol. When he walked up to me at work and told me this i kinda just started laughing. But i believe he learned his mistake. He hasn't had a phone for the past couple days and its killed him lol
    02-16-2012 06:26 PM
  4. sellers86's Avatar
    download an actual rom and flash it via recovery (assuming he has the right recovery installed)
    02-16-2012 08:08 PM
  5. itsrayray's Avatar
    It gets stuck at the VM screen when try to boot. And the when try to get into recovery all it is a black screen
    02-16-2012 08:23 PM
  6. Eollie's Avatar
    follow the directions in the fix a black screen thread it should be able to recover from a rom mangler flash.
    02-16-2012 08:48 PM
  7. Atmazzz's Avatar
    Try this to see the recovery menu while in black screen.
    Install this: New pre-packaged ADB installation
    Next Install Java
    Now go to Droid@Screen
    Droid@Screen will let you see the phone's recovery screen on the computer. He can then install the correct files he needs. He will need a ROM on his SD card to flash and then he will need to install the correct recovery using ADB. Read here for more info on getting that done.
    itsrayray likes this.
    02-16-2012 08:52 PM
  8. itsrayray's Avatar
    Next Install Java
    I'm getting him to attempt it. But I'm gonna do this on my comp so incase he can't do it. I will
    02-16-2012 10:26 PM
  9. itsrayray's Avatar
    Next Install Java
    i got the droid@screen working on my pc and i have to say it is kinda snazzy. what i am assuming is that my friends recovery is a working recovery it is just black as it does not have the software needed to properly make the screen work. so by using this droid@screen i should be able to flash a rom with the needed kernal to boot up and then i should be able to flash a new recovery?
    please correct me if i am wrong....
    02-17-2012 07:05 AM
  10. anthonycr's Avatar
    Thats correct.... just hope that there really is a recovery there
    02-17-2012 07:21 AM
  11. itsrayray's Avatar
    i believe there is. I can use the camera(select key) when first boot into recovery and it will reboot phone, as reboot is always at the top in the main menu.
    02-17-2012 07:44 AM
  12. itsrayray's Avatar
    sorry had to post this. I was messing around lol.
    anthonycr likes this.
    02-17-2012 08:59 AM
  13. itsrayray's Avatar
    I got backside on there and about to put bobs recovery on there
    02-17-2012 06:07 PM
  14. anthonycr's Avatar
    Hahaha That's so cool.
    02-17-2012 06:12 PM
  15. Atmazzz's Avatar
    So you were able to see the recovery with Droid@Screen?
    02-17-2012 06:21 PM
  16. itsrayray's Avatar
    Got everything OK now :thumbup:
    02-17-2012 08:03 PM
  17. thewraith420's Avatar
    I've done that before lol
    02-17-2012 08:04 PM
