Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Like Tree50Likes
  1. #26
    curtis1973's Avatar
    King Of Pants
    Posts
    ROM
    CM10/Sense
    Default
    this is a must read. there's info here i hadn't even read yet and i tend to read way back in the forum. this consolidates many sources in one thread. nice to have,thanks for putting it together :thumbup:
  2. #27
    jaredw444's Avatar
    Posts
    Global Posts
    172 Global Posts
    ROM
    BOBZ CM9
    Default Re: [GUIDE] 2012 Optimus V Reference Guide (Start here!)
    Don't believe all the hype about Rom manager, it works fine never had a single problem with it on my optimus v, intercept(by the way the worst phone ever made...EVER), triumph or my eee pad transformer. i have used almost every menu option and never had an issue.
  3. Thread Author  Thread Author    #28
    LeslieAnn's Avatar
    AC Forums Android Developer
    Posts
    ROM
    Harmonia 3
    Quote Originally Posted by jaredw444 View Post
    A. Rom manager black screens newer phones because it installs an incompatible recovery.
    B. The roms listed in it for the OV are not only old, and will black screen a newer OV, but were NOT put there by the rom developers. In other words, anyone can put a rom on there regardless if they made it or not. Loaded with spyware, or not.
    If you read and research, yes, it can be used relatively safely, but most people who use it are looking for an easy way so they don't have to read about it.
    There are PLENTY of horror stories about that program, especially with the OV.
    And since you aren't the one having to clean up that mess every time, please don't go telling people that it works fine when in fact it clearly does not.
    Harmonia Developer for Optimus V, Optimus Elite, One V, Evo V, Evo Shift, Evo V
    Donate here if you feel inclined to brighten my day.
    Thanked by:
    srkelley likes this.
  4. #29
    jaredw444's Avatar
    Posts
    Global Posts
    172 Global Posts
    ROM
    BOBZ CM9
    if they were smart and did the research they wouldn't jack up there phone. its common sense download your roms from the creators. and use rom manager to flash them. i say rom manager is fine because you have to use it right most of the people who mess up their phones with it just flash and go. when you test out a new app like rom manager make a back up and test it out,(and i have the new version of the optimus,) so you know what the problems are. and by now any one with an optimus should know what and what not to do with rom manager.
    For the new people listen to people who have done alot with android and DO RESEARCH... extensively on multiple sites. and i wasn't trying to upset leslieAnn. this thread is very good, and is one of the reason i tried rom manager just to try and work it on the lg optimus. if you read the the thread and follow the basics of roms and rom manager then you'll never have a problem.
    my Apology.
  5. #30
    Thats right. By itself ROM Manager is good concept and probably created well. It is possible that the execution is what is giving it the bad name. I have not used it or seen it, so I cannot be sure.
  6. #31
    jaredw444's Avatar
    Posts
    Global Posts
    172 Global Posts
    ROM
    BOBZ CM9
    you just gatta try stuff out.. and always make a backup(it'll save your ****). and once you get a hang of stuff then you really get to have fun and try and do new stuff.. right now trying to turn pictures into a kind of slide show boot animation,
  7. #32
    riggerman's Avatar
    Posts
    ROM
    AOKP 4.1.1
    my Apology.
    The problem with this is, people who are going to use ROM Manager don't do their research. They are usually looking for quick, easy, one click method and don't know anything about Android in general, let alone their particular device. Once they get root (usually by a one click method) they are going to look for another one click method to install a recovery and flash a rom. ROM Manager will not install the correct recovery for the V and the roms listed for the V are old, out dated and posted by the developers. Please stop advocating its use as more noobs will use it blindly resulting more soft bricks and requests for help.
    adouglas00 likes this.
  8. #33
    GREAT information! thank you!!!
  9. #34
    Jakethedrummer's Avatar
    Posts
    ROM
    G-T-R Reloaded
    Yes, excellent information! I was wondering though, when I rooted my phone with gingerbreak.apk v1.2, it installed an app called superuser. Is that a rom manager? I cant seem to find anything that superuser does that is worth keeping it on my phone except bugging me every time an app wants permission for something
  10. #35
    anthonycr's Avatar
    Themer. You've seen them
    Posts
    Quote Originally Posted by Jakethedrummer View Post
    All superuser does is give permission to apps. Say yes when those popups come up, it may be annoying, but the app is the way other apps ask for certain permission. Like on windows 7 when it asks "Do you want this program to make changes."
    Thanked by:
  11. #36
    Posts
    ROM
    G-T-R Reloaded
    Quote Originally Posted by anthonycr View Post
    Oh alright, so I should definately keep the app then?
  12. Thread Author  Thread Author    #37
    LeslieAnn's Avatar
    Posts
    ROM
    Harmonia 3
    If you remove it, you will lose root.
  13. #38
    Posts
    ROM
    G-T-R Reloaded
    Quote Originally Posted by LeslieAnn View Post
    that would be bad lol
  14. #39
    josh2903's Avatar
    Posts
    ROM
    Varies
    This is an excellent guide. Thanks for making this it really helped!
  15. #40
    Link2999's Avatar
    Posts
    Global Posts
    122 Global Posts
    Gingerbread IHO Rom List/Information got deleted. (Bad link now)
  16. #41
    My Hauwei U8180 is in a boot loop form Clockworkmod Recovery when I go to reboot recovery it gets to the the logo and stays there for a while but then goes back to ClockWorkmod recovery. When I do a hard reset the first stage is successful but the second is a fail and it says update fail. When I attempt to install a zip card form the sdcard it says no file found. I can backup, restore and advanced restore. Can anyone help me please? I really need help
  17. #42
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Wrong forum wrong thread see the thread you created in the Optimus S section for my reply and please try to avoid this type of double posting
    Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
