| | [GUIDE] APK's, their purpose and safe or not to remove (big!)
This contains Froyo, Gingerbread, ICS, Cyanogenmod Green = Safe to remove. Orange = Remove with caution Red = Do not remove Note: The effects of removing certain apps can change depending on what version of Android and which rom you have. CM responds differently than stock, GB responds differently than Froyo. A AccountAndSyncSettings – Syncs settings to Google, especially important to Gmail. Do not delete. Android_VirginUS-Chat – Virgin Mobile Chat forum app. Safe to remove. AndroidUTSManager – Possibly Time sync system. Not recommended to delete. ApplicationsProvider – Provides the list of installed apps to Market. Delete at your own peril. B BackupRestoreConfirmation - restores sync'd Google settings. Do not remove. Bluetooth – Bluetooth connection system. Do not remove if you use Bluetooth. BluetoothServices - Bluetooth connection system. Do not remove if you use Bluetooth. Browser – Stock Android web browser. Semi-safe to remove, can break bookmarks, voice search and possibly market. C Calculator – Calculator. Safe to remove. Calendar – Calendar app. Safe to remove. CalendarGoogle - Calendar app. Safe to remove. CalendarProvider -sync system for Calendar. Safe to remove. Camera – Camera app. Do not remove if you use your camera. CarHomeGoogle – Utilities to make using your phone safer while driving. Safe to remove. CertInstaller – Wifi certificate installer. Do not remove. ChromeBookmarksSyncAdapter – syncs Chrome bookmarks. Safe to remove. ChromeToPhone – syncs Chrome bookmarks Safe to remove. CMParts – Settings in Cyanogenmod roms will force close without this. Do not remove. CMScreenshot – Screen capture application. Safe to remove. com.google.android.marvin.kickback – Provides keyboard feedback through vibration. Safe to remove. com.google.android.marvin.soundback – Provides keyboard feedback through clicks. Safe to remove. com.google.android.marvin.talkback – Provides keyboard feedback through voice. Safe to remove. Contacts – Your contact list. Do not remove. ContactsProvider – Syncs contacts. Do not remove. Cyanbread – Stock Cyanogenmod theme. Do note Remove unless you have an alternative installed. D DefaultContainerService – Needed for installing apps. Do not remove. DeskClock – Clock and alarm system. Safe to remove Development – Development app. Safe to remove. DownloadProvider – Handles (all) web browser downloads. Do not remove. DownloadProviderUi – Browser download interface. If removed, you won't see download status. DrmProvider – Handles DRM for media that contains it. Do not remove or you will break said media. DSPManager – Equalizer for tuning audio. Safe to remove. DunServer – Possibly part of the VPN system. Delete at your own risk. E Email – Email app. Safe to remove, but will make it impossible to setup your phone/Market with Exchange – email transport system. Do not remove. ExternalMemoryTest – Possibly part of over the air provisioning. Possibly safe to remove, but not recommended. F FM – FM radio player. Not functional on Optimus V. Safe to remove. Fotakill – Disables over the air updates. Depending on rom and phone, may be safe to remove (safe to remove on the OV). G Galaxy4 – Live wallpapers. Safe to remove. Gallery3D – Picture gallery utilty. Safe to remove GalleryGoogle – Picture gallery utilty. Safe to remove GenieWidget – Stock news and weather app. Safe to remove. Gmail - Gmail app. Safe to remove, but can make it harder to setup your phone/Market with Gmail GoogleBackupTransport – Handles backup of settings. Safe to remove. GoogleCalendarSyncAdapter -sync system for Calendar. Safe to remove. GoogleContactsSyncAdapter -sync system for Contacts. Safe to remove. GoogleFeedback – Forceclose reporting for Gapps. Safe for the phone to remove, but could cause problems for Gapps. GoogleLoginService - Google login system. Do not remove. GooglePartnerSetup - In App purchases? Not recommended to remove. GoogleQuickSearchBox – Search box widget. Safe to remove GoogleServicesFramework – Google login system for Gapps. Do not remove. GoogleTTS - Text to speech. Should be safe to remove, but is needed by Google Maps. H HiddenMenu – Hidden programming menus. Don't delete. HTMLViewer – Filters html to be more compatible. Safe to remove, but not recommended. HoloSpiralWallpaper – Live wallpapers. Safe to remove. I J K KeyChain – Possibly password tool similar to Ubuntu. Not recommended to be removed. L LatinIME – On screen keyboard. Safe to remove if you have an alternative installed. Launcher2 – Stock Froyo launcher. Safe to remove, if you have an alternative installed. LgHiddenMenu – Hidden menu settings/phone codes. Do not remove. LGSetupWizard – Either part of initial setup, or account setup. Remove at your own risk. LiveWallpapers – Live wallpapers. Safe to remove. LiveWallpapersPicker – Live wallpaper Picker. Safe to remove if you don't use live wallpaper. M MagicSmokeWallpapers – Live wallpapers. Safe to remove. Maps – Google Maps/Navigation. Safe to remove. MarketUpdater – Starts with Market and checks for updates. Safe to remove. MediaProvider - Handles ringtones and such, DO not remove. Mms – MMS system. Do not remove. Music – Music player. Safe to remove. N NetworkLocation – Provides location through towers instead of gps. Not recommended to remove. NoiseField – Live wallpapers. Safe to remove. O OneTimeInitializer – Runs after first flashing of Gapps to allow you to chose which you want. Safe to remove. OpenWnn – Chinese or Japanese keyboard. Safe to Remove P PackageInstaller – Installs apps. Do not remove. Pacman – Package manager. (?) Do not remove. PhaseBeam – Live wallpapers. Safe to remove. Phone – Phone dialer. Do not Remove. PicoTts – Text to speech. Should be safe to remove, but is needed by Google Maps. PinyinIME – Chinese or Japanese keyboard. Safe to Remove Poynt-Virgin – Poynt app. Safe to remove. Protips – Tips widget. Safe to remove. Provision – New phone setup wizard. Should be safe to remove. Q QuickSearchBox – Search box widget. Safe to remove, but may break the search button. R S Scvngr – Scavenge App. Battery hog. Safe to Remove SelfServiceAssistant - Virgin activation app. Safe, but not recommended to remove. Settings – Settings system. Do not remove. SettingsProvider – Part of the settings sync system. Do not remove. SetupWizard – Wizard to setup email. Do not remove. SharedStorageBackup - Possibly USB connection menu. Do not remove. SoundRecorder – Sound recorder. Should be safe to remove. SpareParts – Extra settings for Cyanogenmod. Safe to remove. SpeechRecorder – Part of speech recognition setup. Do not remove if you use voice. SPGMyAccount – Useless shortcut to web. Safe to Remove Superuser – Handles root/SU permissions. Do not remove. SystemUI – Part of the user interface. Do not remove. T Talk – Google Talk. Possibly safe to remove, but could break Market. TelephonyProvider – Phone system. Do not remove. ThemeChooser – Cyanogenmod theme system. Do not remove. ThemeManager – Cyanogenmod theme system. Do not remove. Trebuchet – Stock ICS launcher. Safe to remove, IF you have an alternative launcher installed. TtsService. - Text to speech. Should be safe to remove, but is needed by Google Maps. Twidroyd – Twitter. Battery hog. Safe to Remove. U Usbstorage – Usb storage. Do not remove if you access files on your phone from your computer. UserDictionaryProvider – Dictionary for word prediction on keyboards. May be safe to remove. V Vending – Market App. Safe to remove, but you won't have Market. Virgin_Mobile – Useless shortcut to web. Safe to Remove VisualizationWallpapers – Live wallpapers. Safe to remove. vmu_store_release_candidate – Virgin Mobile app. Should be safe to remove. VoiceDialer – Voice dialing. Safe to remove. VoiceSearch – Voice search,. Safe to remove. VpnDialogs _ Part of the VPN system. Safe to remove if you aren't using it. VpnServices – VPN adapter. Safe to remove. W WAPPushManager – Tethering connectivity. Safe to remove if you don't use tethering/access point mode. WHERE – Where Application Battery hog. Safe to Remove. Battery Hog. X Y YouTube – Youtube viewer. Safe to Remove. Z | |
