I'm making this thread so that those who miss what I said in the IHO thread don't miss out on the extremely simple solution to many peoples mms problems that I accidentally discovered.
If you are currently having trouble sending mms messages (pictures, sounds, videos) from your optimus v, I suggest you make sure that the AREA CODE is present in your contact info. MMS will not work without the area code in the contacts phone information. If you can't send pictures after putting in the area codes of your contacts, then that was not your problem. However i suspect this is a problem that has plagued any unsuspecting androidians.
