I would like to point out that that there is hardly anything that I've observed or written (here or in the IHO thread) that contradicts with what I've seen LeslieAnn say (other than the existence of 122, which is not significant in itself, and probably just due to newer kernels since Zefie's days). On the contrary, ever since I started following this forum a year ago, I've found LeslieAnn's writings on the subject to be islands of fact and reason in a sea of noise. Having built overclocked PCs myself for almost 20 years, I recognize that.
This thread is an excellent contribution in that LeslieAnn lays out a process for determining the right OC settings ? process being the key word here.
There are a lot of myths in the area of over/underclocking, partly due to lack of understanding, which leads to this pursuit of "the one perfect setting". There is no such thing, both because each phone's hardware is different, but also because we all use our phones in different ways.
So ideally, people need to go through this process to determine the right settings for them.
The classic recommendation of Min=480, Max=two notches down from stable is a great starting point; or a great default for those who (understandably) don't want to go through this process -- although it still requires some work to determine Max. There is nothing wrong with simply sticking to that. But that doesn?t make it ?the best setting?. It?s simply the best starting point ? and not a bad place to be if that?s where you end up staying.
