Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
Like Tree12Likes
  1. #26
    Nate456's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock, CM10, AOKP
    Default
    Bump
    Sent from my Droid using Tapatalk 2
  2. #27
    RyanJKremer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Always changing!
    Default Re: [GUIDE] How I port
    Quote Originally Posted by rukin5197 View Post
    For MIUIv4, for phone FC, I had to decompile the framework.jar in /system/framework (for both BASE and PORT) and go to com/internal/android/telephony/cdma and replace all the files with the ones from BASE.
    What method are you using to decompile framework.jar? I'm trying to use the jadclipse plugin with Eclipse to decompile, but I am new to Eclipse and coming up with no good help on the Google. Am I over-complicating this?
    As a side-note, I am using Ubuntu 12.04. All of the windows-based java-class decompilers are less-helpful for me.
    Thank you for any help you can offer.
  3. #28
    EarthnFire78's Avatar
    YAY!!! ME :)
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Custom ROM & Kernel
    Quote Originally Posted by RyanJKremer View Post
    Here is how I would work with the jar files for porting if I decompiled anything it Linux.
    first unzip the jar file, in this case framework.jar
    Code:
    unzip -q framework.jar classes.dex
    next decompile the classes.dex using a baksmali.jar and set the api level to o/s version.
    Code:
    java -Xmx512m -jar baksmali.jar -a 10 classes.dex
    Replace the files needed and compile and compress a smali.jar is used to compile.
    Code:
    java -Xmx512m -jar smali.jar -a 10 out -o classes.dex
    zip -r -q framework.jar classes.dex
    RyanJKremer likes this.
  4. #29
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Always changing!
    Default
    Thanks for the quick reply! Looks like I've got some learning to do! I'll google my way through these steps and see where I get.
  5. #30
    YAY!!! ME :)
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Custom ROM & Kernel
    No problem
    Just a note I would not use apktool.jar to decompile a jar file, it is better to unzip it and use a baksmile.jar/smaile.jar to decompile the classes.dex and zip it back up. That way if the jar is signed, the META-INF is not messed with.
    Of course the only time I use baksmile.jar/smaile.jar apktool.jar is with my Cygwin built tool. I'm adding a porting function for LeWa and MIUIv4 ROMs.
  6. #31
    ThatGuyLurkin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Apktool is different in Linux?
    Or is it different commands/
  7. #32
    YAY!!! ME :)
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Custom ROM & Kernel
    Quote Originally Posted by ThatGuyLurkin View Post
    The command are the same for the most part if using the jar file with out the script or batch file.
    sammyz likes this.
  8. #33
    34
    34 is offline
    34's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do the processors of the two devices have to be an exact match?
  9. #34
    Nate456's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock, CM10, AOKP
    Default
    Quote Originally Posted by 34 View Post
    I don't think so because I ported backside to my droid with few problems.
    Sent from my Shole using Tapatalk.
    sammyz likes this.
  10. #35
    34
    34 is offline
    34's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK, thanks. Will I have problems with my phone's resolution?
  11. #36
    brotherswing's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    Default
    I'm curious too, there's an appalling lack of development for my wife's WFS, and I've thought about trying to port BACKside to it.
    thus he spake.
  12. #37
    Nate456's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock, CM10, AOKP
    Default
    Just the boot animation.
    Quote Originally Posted by brotherswing View Post
    thus he spake.
    Development for the Droid is almost dead that's why I ported it and CyanogenMod didn't have the customiazation like backside.
  13. #38
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    thus he spake.
    You could do that in 10 minutes. MDPI device makes it easy
  14. #39
    jonny5449's Avatar
    AC Citizen
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cm7/Cm9/Cm10
    Default
    thus he spake.
    U could probably do it easily another mdpi device =easy
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
  15. #40
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    Default
    I probably will, once I get caught up on everything. Kids, work, making themes, and running DHoT keeps me pretty busy!
    thus he spake.
    ThatGuyLurkin likes this.
  16. #41
    sammyz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    OV:quattrimus OM:BACKside
    Quote Originally Posted by Nate456 View Post
    I should of did that for my step brother's droid.....
  17. Thread Author  Thread Author    #42
    rukin5197's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUIgb | AOKP
    Default
    thus he spake.
    All honesty I would build from Jerry's git. Just throw in the wfs device/vendor folders and mess with the code a bit and compile. It will have all the features as backside. This will be better than porting, but porting will be easier alas
    Sent from my PC36100 using Tapatalk 2
  18. #43
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    Default
    If I do actually pursue this, that's how I would do it.
    thus he spake.
  19. #44
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    Default
    Okay, I didn't. But I want to. I just think it would run better. Until I do, I tried this. It works as advertised, thank you! Now I need to figure out all the bugs. That shouldn't be to hard, just time consuming.
    thus he spake.
    sellers86 and rukin5197 like this.
  20. Thread Author  Thread Author    #45
    rukin5197's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUIgb | AOKP
    Default
    Glad to know this old baby still works
