[GUIDE] How I port
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
I thought I'd share http://www.google.com/gwt/x?gl=us&c...2012/02/how-to-deodex-rom-sdx-developers.html
Its all about deodexing and I noticed at the bottom it says that apps deodexed using scripts will force close if they have sound files because the files are compressed and they malfunction. It suggests manually deodexing them instead (using baksmali). I thought this was interesting since I know alot of you people that are porting are experiencing force closes with apps.;)
RyanJKremer
155
50
For MIUIv4, for phone FC, I had to decompile the framework.jar in /system/framework (for both BASE and PORT) and go to com/internal/android/telephony/cdma and replace all the files with the ones from BASE.
What method are you using to decompile framework.jar? I'm trying to use the jadclipse plugin with Eclipse to decompile, but I am new to Eclipse and coming up with no good help on the Google. Am I over-complicating this?
As a side-note, I am using Ubuntu 12.04. All of the windows-based java-class decompilers are less-helpful for me.
Thank you for any help you can offer.
EarthnFire78
YAY!!! ME :)
Jan 1, 2012
964
232
Here is how I would work with the jar files for porting if I decompiled anything it Linux.
first unzip the jar file, in this case framework.jar
Code:
[SIZE="2"]unzip -q framework.jar classes.dex[/SIZE]
next decompile the classes.dex using a baksmali.jar and set the api level to o/s version.
Code:
[SIZE="2"]java -Xmx512m -jar baksmali.jar -a 10 classes.dex[/SIZE]
Replace the files needed and compile and compress a smali.jar is used to compile.
Code:
[SIZE="2"]java -Xmx512m -jar smali.jar -a 10 out -o classes.dex
zip -r -q framework.jar classes.dex[/SIZE]
Reactions: RyanJKremer
RyanJKremer
155
50
Thanks for the quick reply! Looks like I've got some learning to do! I'll google my way through these steps and see where I get.
EarthnFire78
YAY!!! ME :)
Jan 1, 2012
964
232
No problem :)
Just a note I would not use apktool.jar to decompile a jar file, it is better to unzip it and use a baksmile.jar/smaile.jar to decompile the classes.dex and zip it back up. That way if the jar is signed, the META-INF is not messed with.
Of course the only time I use baksmile.jar/smaile.jar apktool.jar is with my Cygwin built tool. I'm adding a porting function for LeWa and MIUIv4 ROM'S.
brotherswing
555
167
I'm curious too, there's an appalling lack of development for my wife's WFS, and I've thought about trying to port BACKside to it.
thus he spake.
Nate456
462
120
OK, thanks. Will I have problems with my phone's resolution?
Just the boot animation.
thus he spake.
Development for the Droid is almost dead that's why I ported it and CyanogenMod didn't have the customiazation like backside.
Sent from my Shole using Tapatalk.
scout13fox
