Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Like Tree12Likes
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Default [GUIDE] How I port
    Okay, so there have been many many many requests on porting ever since I've ported things. Instead of getting requests all the time to port things, I'm going to give you my knowledge on porting. Sorry if it is scrambled everywhere, but I like to get off topic a lot
    First of all, you're going to need to know a zip file inside and out. That means what all the files mean, especially the .so files. These are a matter of boot or not on a ROM.
    Second, of course, you're going to need to know obviously which version of the ROM you are trying to port. So if it is a GB ROM, try to use CM7 as your base. Or even our new AOSP gingerbread (thanks redbaron )
    Third, there's three folders in a zip that are the most important ones you're going to deal with. The apps, frameworks, and media folders. These are what makes the ROM (especially themed ROMs) so cool. All the features, options, etc.
    Fourth, patience and adb are going to be your best friends. If it doesn't boot, you're going to need to read the adb to see the problems and patience, because a lot of pulled batteries are going to be needed in these situations.
    Fifth, I'm going to be referring to the ROM you are basing it off of, be it tdm's CM9, any of the IHOs, as BASE. I'm going to be referring to the ROM you are porting as PORT. Just to simplify things and not let things get a little confusing.
    So, if you're wanting to port a regular ol' CM7 themed ROM from another phone, you're going to do this -
    Delete the apps, framework, and media folder from BASE. Replace them with the folders from the PORT. Then it should boot.
    If it doesn't boot, there's usually one .so file in /system/lib that determines boot or not. That file is 60% of the time libandroid_runtime.so. Delete it from BASE and replace it with PORT.
    That is a plain port. Simple.
    Now, for CM9, there is a little bit of a difference. There are two important files located in BASE in /system/media called LMprec_508.emd and LMprec_600.emd that are VERY important. Without these, I couldn't get MIUIv4 to boot. It took a little while to figure this out, lol. So just make sure when you port CM9 based ROMs that you have the originals in there.
    Now don't go off thinking you can do this with just any ROMs. There are limits. For example, you can't port Sense, TW, MotoBlur, or any other ROMs that big for that matter. If it is based off of CM7, then you can port it. If it is based off CM9, then you can port it.
    Remember- This isn't full proof. I have encountered problems with CM9 based ROMs with this method (phone FC) and a few other problems with other ROMs.
    Some fixes I've run into that might be note worthy
    For LeWa, for data, I've had to replace the apn.xml from the framework-res.apk (/res/xml). from BASE to PORT
    For MIUIv4, for phone FC, I had to decompile the framework.jar in /system/framework (for both BASE and PORT) and go to com/internal/android/telephony/cdma and replace all the files with the ones from BASE.
    For 99% of ROMs
    To fix MMS on almost all ROMs, you're going to have to do this:
    decompile the framework.jar (use apktool), go into the folder I mentioned for the phone FC fix for MIUIv4, and replace a file called CdmaSMSDispatcher.smali with the one from the BASE.
    Now hopefully this causes two things:
    -More of an option of ROMs available
    -Me stop getting requests
    Happy porting
    Thanked by 17:
    + Show/Hide list of the thanked
  2. Thread Author  Thread Author    #2
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Default Re: [GUIDE] How I port
    For the Hardcore advanced wannabe porters only!
    I thought that I would throw this guide in here because I made it for another person and it somewhat belongs. I made this for a person porting Sense to the Triumph and thought some of you could contribute. You could most likely use this to port ROMs such as Sense, TW, MotoBlur, etc.
    How to port Sense.
    This is a very difficult process that I hope you'll understand.
    First step is to find a device that is preferably VERY similar to your device, in this instance I guess we would use the htc thunderbolt, which I've been told multiple times that it is used for the MT.
    You're going to want to use CM7 for parts. Simple enough.
    I will be referring the Sense ROM to SENSE and CM7 as BASE to simple things up. So remember that.
    When I say replace, I would recommend deleting from one and adding it with the other
    Open up Sense and Base in different windows.
    Put in the boot.img from Base into Sense (make sure you put the original boot.img in some other place that you'll remember)
    go into /system/usr on both
    replace keylayouts and keychars from Base into Sense (this is just your keys)
    download dsixda's kitchen ()
    Get the ROM you have so far set up in it and what not (I'm a little fuzzy at this part)
    Once you get done with that, run the menu in terminal and navigate your way to decompile the boot.img (action key- "a") and then run the same thing except run the action key "w" to decompile the original boot.img. So the key here is to decompile both boot.img's.
    Go into the ramdisk on both and go into init.rc
    THE MOST IMPORTANT PART IN THIS (THE MATTER OF BOOT AND BOOTLOOP) IS THE LINE
    "export BOOTCLASSPATH" near the top. It will have a bunch of lines after it. Now in the Base's boot.img, delete this whole line. Replace it with the lines from Sense's boot.img.
    Now you can add anything else you want that looks like it belongs (preferably anything sense related)
    Don't recompile the boot.img yet.
    Now we add a2sd. To do this, just follow this guide ()
    The only thing you do in there is the edits to the init.rc, don't listen to the decompiling/recompiling mentions. Now you can go back into the menu for the kitchen and recompile the boot.img (action key - "b"). Now don't compile the WHOLE ROM, just take the new boot.img in working_** and put it into the Sense zip.
    Now you're going to want to download my ROM (sorry, just don't feel like uploading each individual file)
    And go into the /system/bin on both
    these are the files you're going to need: a2sd, bash, apps2sd.hlp, busybox.a2sd, chka2sd, jita2sd, launcha2sd, starta2sd, and maybe possibly sh (try once without it)
    And you're going to want to set permissions for each one of these in the updater-script (look at mine for references)
    Now also look at my zip and you'll see move_cache_sd. Put that in yours and set permissions for it in updater-script (use mine for references)
    After that, the other stuff is mainly just getting rid of all the bloatware, (look in /system/app and /system/media) I wouldn't delete any libs as of right now. If you try to flash it and it reboots recovery then it is too big.
    If it is too big, you're probably going to want to move a lot of the apps to data. To do this, just make a file called data/app/put_your_apps_here on the root of the zip. You're going to have to set permissions for it in the updater-script, but use the test.zip I sent you in the original.
    This will most likely get you booted. Nothing will likely work. Which is expected. If you have any problems, just use logcat. It will be your bestfriend. Have fun porting
    Thanked by 4:
    Badboytoast likes this.
  3. #3
    Default
    Where can I find more info regarding the new aosp?
    Sent from my LG-VM670 using Tapatalk 2 Beta-5
  4. #4
    rebel69ization's Avatar
    Posts
    ROM
    Cold As Ice /Hydro ICS
    Default
    Gannon the "sense"ov is bad a** do ya think ur gonna do anything else to it?
    tappin',talkin' from my ov
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Quote Originally Posted by rebel69ization View Post
    If the ROM for the Optimus one gets data, then I'll port it over.
    Thanked by:
  6. #6
    cammykool's Avatar
    Resident idiot
    Posts
    ROM
    Harmonia 3, Stock
    could i use this to port CTMod from the prevail after never doing it before or should i do it in my ubuntu box?
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Quote Originally Posted by cammykool View Post
    You can use this guide to port any ROM you would feel. That's my main reasoning for making it
    Just use knowledge from it
  8. #8
    arnold1997's Avatar
    Posts
    ROM
    My Version Of CNA
    Default
    is it possible to port the sense 2.1 gingerbread from galaxy ace lol im going to see if it can be done
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Quote Originally Posted by arnold1997 View Post
    Make sure you use the 2nd post. It's very time consuming and what not but it can be done.
  10. #10
    cammykool's Avatar
    Resident idiot
    Posts
    ROM
    Harmonia 3, Stock
    but you said to use all your sense stuff and this is not a sense rom its stock GB
  11. Thread Author  Thread Author    #11
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    What? Use my first post and port that ROM. Lol
  12. #12
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,017 Global Posts
    ROM
    Stock
    I'm not a dev, but I'd like to add that anyone who ports something please think VERY hard before posting / releasing it. Be prepared to support it, be as detailed as possible about problems / issues and realize the responsibility you undertake by distributing software for others to use. Yes, it's their choice, but there are those who flash blindly.
  13. #13
    kcls's Avatar
    Posts
    ROM
    IHOCM7.2 || AOKP
    Default
    Quote Originally Posted by cole2kb View Post
    Yup, I agree with this 100 percent. I really, really don't want the Optimus V forums to be more cluttered then they already are with ROMs people port and then don't support. Even worse, one that has bricking abilities. Then we'll get 50 more "Help I've bricked my phone with [such and such's unsupported ROM]"
    Thanked by 3:
    sellers86 and dwappo like this.
  14. #14
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    So I can fix phone FC's on AOKP with what you said ??
  15. #15
    Default
    Is porting this simple? I don't think so lol
    Sent from my Droid using Tapatalk
  16. #16
    So can we use the cmdasmsdispatcher trick to fix mms on ics roms for the v and s? Would switching it out from CM7 work? Or from another CM9 Virgin phone like the triumph??
  17. Thread Author  Thread Author    #17
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Oh I agree as well. I'm just trying to teach the community to help them become better. These guides are obviously noob proof, and not just anybody can do it. Although I was a little specific.. lol.
    If it turns for the worse I can just take down the guide.
    But after all, this is where I started so maybe others could blossom from this?
  18. Thread Author  Thread Author    #18
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Quote Originally Posted by olmos.lalo View Post
    I haven't tried that but I wouldn't think it would work. But the Triumph thing was brought up before, I don't remember if it worked or not.
  19. #19
    Hmm I tried last night but I couldn't get the damn jar to sign. Don't know why (using apktool) But Btw Thanks For This! Im a complete noob and I already ported the newest LeWa from O1 Thanks a lot!
  20. #20
    Posts
    ROM
    Default
    Gannon, if you can port it ill try it. I'm not scared, I just like seeing the different systems and such on a phone that's not supposed to have them. Thanks for all you do for us.
  21. #21
    staticmaal's Avatar
    Posts
    ROM
    CM7 Gingerbread 2.3.4
    What kind of sense rom do I use just any or it has to be stock deodexed?
  22. #22
    anthonycr's Avatar
    Themer. You've seen them
    Posts
    Default
    I thought I'd share
    Its all about deodexing and I noticed at the bottom it says that apps deodexed using scripts will force close if they have sound files because the files are compressed and they malfunction. It suggests manually deodexing them instead (using baksmali). I thought this was interesting since I know alot of you people that are porting are experiencing force closes with apps.
  23. #23
    staticmaal's Avatar
    Posts
    ROM
    I tired to make a Sense port for the MT and got status 0 instillation aborted.
  24. #24
    sammyz's Avatar
    Posts
    ROM
    OV:quattrimus OM:BACKside
    Default
    This is how I port to the optimus m, it has the list of all the files needed to be changed and I think I may need to add that one lib file gannon was talking about because there was a couple of roms I couldn't get to boot....
  25. #25
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    -bump- :-)
