i wanna try as many roms as possible found a couple but i know there has to be more :) please post them here
Printable View
Here's a link to all the major OV ROMs in one spot:[Only registered and activated users can see links. Click Here To Register...]
You're welcome ;)
They all are right here. Just look, the "top two" are Harmonia 2 and backside iho. There's others like MIUI, and the ics ROMs that are still in alpha stage.
That list is old,
As it is there are something like 12 different ROMS to choose from, most are very well supported, and as it is I'm liking my own ROM: it is by fare own of the faster ROMS in boot-up time.
A good place to start looking would be[Only registered and activated users can see links. Click Here To Register...]
i beleive that stickies been replaced with [Only registered and activated users can see links. Click Here To Register...] one actually. most of the roms mentioned in mmarz thread are not around anymore and none of the newer ones are mentioned.Quote:
Originally Posted by droidmyme [Only registered and activated users can see links. Click Here To Register...]
as dwappo said tho just look threw the first page or so of this forum and the top roms have threads that are always there.
Start off with, " There are no top roms ".
The choice is yours, as each rom offers different features.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
i mean top like upkeep
Then your talking Mirage, Backside, and Bobz's roms. Also Quatrimus for ICS, but it's in alpha.Quote:
Originally Posted by blizard [Only registered and activated users can see links. Click Here To Register...]
yea i have been useing backside for like 6months jus wanting to try some other one i have tryed quatrimus
If you really want to know,
Gingerbread ROMs
IHO GB CM7 ROMs are located here- [Only registered and activated users can see links. Click Here To Register...]
ICS ROMs
TDMs ICS- [Only registered and activated users can see links. Click Here To Register...]
Froyo ROMs
Harmonia 1.7- [Only registered and activated users can see links. Click Here To Register...]
These aren't the only ones but the main ones.
All the IHO based ROMs have the advantage of being based on CyanogenMod code, so we benefit from an entire world of developers working on that code base. We each pull in changes from there, and make our own changes as well. For the purest CM currently available, try tvall's ROM, for the most basic CM currently available, try Harmonia2, for the most added functionality, try BACKside-IHO, for the most stability, try Mirage or BobZhome. For the cutting edge (meaning not everything works), try Qautrimus (ICS), MIUI, or AOKP.
There are a few new ROMs that appear to be excellent, but only time tells if they will be updated often (which I believe is the basis of your question). ;)
um... *cough, cough* +1 for BACKside... :-)
Thanks
Yes thats exactly wat i was lookin for thanks
Speaking of IHO, as my OM ROM is the fastest I believe in boot-up it is not the cleanest looking. I'm in the works of rebuilding it, to clean it up and redo the app theme: my hope is that it well take the size done.
Decompiling apps and coding takes a while :p
ah... i see you chose BACKside... and that you have a blue theme... try this blue theme i made... im sure youll like it... this zip is flash only so make a backup>wipe cache>wipe delvik>flash zip>reboot>enjoy... :-)
this theme is for BACKside04-01-2012... :-)
I appreciate it thanks this is my new themeQuote:
Originally Posted by clodfelterac [Only registered and activated users can see links. Click Here To Register...]
For my choice
1) icsandwich2. 3.7 v2.
2) iho backside
3) tvall
Then ics cm9 and aokp just for play around.
Where did you find icsandwich2.3.7? is this thaunknownartist's rom?Quote:
Originally Posted by samlin168us [Only registered and activated users can see links. Click Here To Register...]
The question the OP posted was clarified by the poster to be what is the most frequently updated ROM :
Im useing icsandwich2. 3.7 v2. How do i change it on my profile im useing the app?Quote:
If you click on your user name then go to your info page you can click the little edit buttonsQuote:
Agreed. Your OM ROM is my favorite ROM yet.Quote:
Originally Posted by EarthnFire78 [Only registered and activated users can see links. Click Here To Register...]
Sent from my LG Optimus V running OM_MLS v2.2.04-EXT using Tapatalk 2 Beta-6
I've tried them all and I used backside the longest but then I tried mirage, by far my fav as far as performance goes.
Tappatalkin' from My V
Cant find the thread for the mirage rom please post linkQuote:
Originally Posted by rebel69ization [Only registered and activated users can see links. Click Here To Register...]
