13) Reboot into recovery.
14) Go to Backup and Restore, choose Restore. Pick your latest backup.
15) Reboot. Done!
If you want the stock rom with root access, skip step 14. Instead, choose install zip from sd card, and flash jcase's modified SuperUser zip package. Reboot. Done!
If you want a clean start (like I did) skip step 14. Instead, choose install zip from sd card, and flash your favorite rom (and gapps if necessary.) Reboot. Done!
It's in the OP.
Sent from the BACKside of Tapatalk 2
Yeah, wouldn't have posted if it had worked... Just sayingUnless VM pulled it. I had linked directly to the file on their servers.
Re run the Gordita file, you don't have the correct recovery. Gingerbreak won't work after this update, that's part of what Gordita does for you. Did you get any error messages?
The sleep 10 command does result in a unrecognized command....
Sleep is not a standard windows batch command - though lots of people have sleep.exe files installed separately. I never checked if it was added in vista or win7, but I'm 99% sure it wasn't in xp, even with command extensions enabled.
Edit: @brotherswing: you could add a sleep.exe to your zip (just downloaded it and didn't see one). Or maybe just a pause command instead and have the user hit enter. I know... but they never awarded Oscars for the most elegant windows/DOS batch file anyway
Ok this is strange, I spoke to soon. I rebooted once and entered Recovery just found, but restarted once more and now I am back to the old Recovery 3e.
It goes to virgin mobile's page to buy a Triumph.
LOL, what do you think Virgin Mobile is trying to tell us?
Sent from my NookColor using Tapatalk
who has a good download link for this? i cant find it anywhere, i keep getting redirected to the triumph????????
I re-tested all of my links today, they all worked from my Win7 laptop using Firefox. It's probably the way your browser is handling the download redirect.
