Porting help.
I don't know about you guys, but I just put apktool and all it's other needed files in a folder and opened terminal, CD'd to the directory, and ran
Code:
java -jar apktool.jar d apk.apk
And for recompiling
Code:
java -jar apktool.jar b apk
Of course I have the sdk and java installed.
Okay so I decompiled the framework.jar for the BASE and then got a folder called "out" inside I got "apktool.yml"
What do I do next?
What do I do next?
After decompiling, don't you replace the CDMAdispatcher or something like that from another Gingerbread rom?
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Gannon said
I had to decompile the framework.jar in /system/framework (for both BASE and PORT) and go to com/internal/android/telephony/cdma and replace all the files with the ones from BASE.
For 99% of ROMs
To fix MMS on almost all ROMs, you're going to have to do this:
decompile the framework.jar (use apktool), go into the folder I mentioned for the phone FC fix for MIUIv4, and replace a file called CdmaSMSDispatcher.smali with the one from the BASE.
So that CdmaSMSDispatcher is what you need I suppose.
I believe you misunderstood me, I decompiled the framework.jar file and got a folder names "out" with apktool.yml inside it. I don't know how to get to "com/internal/android/telephony/cdma" and I don't know what to do next. Am I supposed to open up apktool.yml with a program? I also don't know how to get to "CdmaSMSDispatcher"
I'm not good with APKtool because I usually use 7 -zip for everything.
Try 7-zip, and if it doesn't work, ill be willing to help if you give me the rom link your porting.
Ill help after school though. :p
Any help works :D
Rom based off BACKside rom (April 9)
https://rapidshare.com/files/3267352468/iDroid_port.zip
ISSUES:
MMS doesn't work
Holding home button crashes rom.
Can't remove boot (I don't know how to)
****** For 3G******
1. Settings
2. Operators
3. Access Point Names
4. Hit menu key, then select "add vpn"
5.For NAME type anything
6. For APN type anything
7. Menu key, then select save.
8. Select created apn
9. You now have 3G
Reactions: Badboytoast
Instead of the whole ROM, just send me your framework.jar and Bob's framework.jar.
Name them something like "frameworkiDroid.jar" and "frameworkBob.jar". I'll do the trick for you.
Kool rom how did you get the English toggles, if you could get mms to work this would be a daily drive for iPhone likes!!! Including my lil bro! To be honest my signal looks stronger,
Could you post the patch please I,ll test mms for you!
kctraci1
