Page 1 of 9 1234 ... LastLast
Results 1 to 25 of 222
Like Tree13Likes
    Default Porting help.
    Hi guys me again (Official Noob) trying to port a rom using Gannon's tutorial/guide. I'm having some problems. I got it to boot, Installed a different launcher (because the original wont work) and basically it's running to my surprise, however many things don't work. I keep getting a constant message saying "android.process.acore" bblah blah blah. I did some research and found no solution. The phone app isn't working, the contacts app isn't working, also when trying to type something up using the keyboard it will close due to the acore message. I'm sure they're interrelated. Also the statusbar will have a sort of cutoff when using some apps.
    Here is the rom I am trying to port.
    If it's too much of a job for me or just too much of a trouble to help me with I'll understand
  2. #2
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Default Re: Porting help.
    Haha small world. That guy, kssood, has learned everything he knows from me. Lol I basically ported that ROM for him
    But back to the business: I wouldn't port from that one. I would port this one:
    It has info on there about the .acore and stuff, so you'll be able to do it yourself.
    Will do first thing tomorrow when I'm out of school, as of now (I'm going to bed, school tomorrow :/)
    Anyway thank you very much, wish me luck
    So I got as far as fixing some issues and all. I'm still having problems trying to figure out how to fix mms, I've read your guide and I don't know what to do. I don't know how to use apk tool, how to decompile files, and all of that. I'm not sure if I have to do it but oh well.
    So how do I fix mms? Can you make it as noob friendly and simple as possible?
  5. #5
    anthonycr's Avatar
    Themer. You've seen them
    Posts
    Default
    Apktool is actualy quite simple once set up correctly
    What you need to do is to download the androidsdk, then download platform tools.
    Then you add the folder containing your platform tools to the PATH in the properties of the computer, so that way you can open up command prompt and jist type "apktool"
    Before I ramble any further... does any of this make sense?
    So far I understand I need download the files, decompress them (if I need to) into a folder, and place that folder into another location. Am I right?
  7. #7
    anthonycr's Avatar
    Posts
    Default
    Quote Originally Posted by BackHandLegend View Post
    Yes yes!! You also need to add java to your variable PATH so apktool can access the java code.
    Once you get it set up, you just type away
    Apktool -d apkyouwanttodecompile.apk C:/locationyouwanttoputthedecompiledapk/nameofapk
    That decompiles^^
    Then
    Apktool -b C:\placeyouputapk\apkname
    And boom, its built. Just remember you need to sign the built apk using signjar.jar
    Edit: I use windows 7
  8. #8
    EarthnFire78's Avatar
    YAY!!! ME :)
    Posts
    ROM
    Custom ROM & Kernel
    Default
    The nice thing about using Linux, is there is no need to miss with paths for apktool. Just drop all three files in /usr/local/bin/ after giving them both root, and making them excitable.
    SuperiorIrkenOrgans 100% CyanogenMod for LGE Optimus devices.
    [CyanogenMod-7 ROM+KERNEL] OM-Mandylion my CyanogenMod-7 ROM build.
    [Recovery] ZenGarden 2.0.2.7-T a recovery to fit all your needs.
    Okay, here is what I did, I got the files "apk tool", and "apk tool install windows" and extracted them to the computer> local disk (c> windows> system32.
    I also installed java in the same directory however whenever I type in "apktool" into the command it gives me a message saying "'java' is not recognized as an internal or external command"
  10. #10
    anthonycr's Avatar
    Posts
    Default
    That means it can't find it
    right click on computer and select properties, then select advanced system settings, then select environment variables. Then scroll down till you see PATH, and click edit. Then at the end of the list put a ";" and then add C:\whereveryourfolderis\java (if the subfolder java is in is called that) and then just click ok.
    Then try typing apktool again into the prompt.
    @earthnfire, I bet its so simple... my dad wont let me partition his hard drive though
  11. Thread Author  Thread Author    #11
    Okay I got to the part until you tell me to type a ";" at the end of the highlighted folder location.
  12. #12
    Badboytoast's Avatar
    Posts
    Global Posts
    822 Global Posts
    ROM
    ICS 2.3.7/ tvall kernel
    If some one gets to port the joy rom could they please post it because my lil bro would like to have that rom! Thanks
  13. #13
    anthonycr's Avatar
    Posts
    Default
    What is the specific location of the apktool and the specific location of the java files ( the C:\name\name thingy)
    Sent from my VM670 using Tapatalk 2
  14. Thread Author  Thread Author    #14
    Well I originally just installed it in the default location. I think you should just tell me where to install everything in a noob way
  15. #15
    anthonycr's Avatar
    Posts
    Default
    Haha ok. So... java installs to C:\Program Files (x86)\java\jdk1.5.0 (assuming you have java 1.5 installed). It will be different depending on what java installed. Just look in the location I just mentioned and use the latest version of java.
    Then follow what I said before and add this location C:\Program Files (x86)\Java\name of the java subfolder add that to the path variables as I described in a previous post.....
    Currently in your PATH, there probably should only be something like C:\Program Files
    Therefore to add another, you simply put C:\Program Files;C:\Program Files (x86)\Java\jdk1.5.0 (OR WHATEVER THE JAVA FILE IS ACTUALLY CALLED)
    That should do it for the java problem
    Edit: I tried to put it as noobishly as possible if I'm doing a terrible job explaining, google may render better results
  16. Thread Author  Thread Author    #16
    Okay so this is all that came before. "C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\12.0\DLLShared\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Windows\System32\java"
    Then without a space or quotes I entered this. ";C:\Program Files (x86)\java\jre6"
    I still get the bad command :/
  17. #17
    anthonycr's Avatar
    Posts
    Default
    I believe you need a jdk installed, not a jre. Jre = runtime environmemt jdk = all the java files. If you have a jdk in the java folder use that instead of the jre6.
    Oh and also.... you MUST run the command prompt as administrator or else it will not have access to the java. That actually could be your problem
    Edit: jre is ok, I think it will work if your run in administrator.
    http://forum.xda-developers.com/showthread.php?t=1466100
    Here's the how to thread on xda in case you haven't found it yet
  18. Thread Author  Thread Author    #18
    Okay so I added entered this C:\Program Files (x86)\java\jre6\bin
    Then I get a message saying "unable to access jarfile C:\System32\\apktool.jar"
    I'm sorry I'm probably being really annoying, if you wish not to help anymore I can understand however if you do want to help what do I do next? I appreciate your patience and help!
  19. #19
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    I don't know about you guys, but I just put apktool and all it's other needed files in a folder and opened terminal, CD'd to the directory, and ran
    Code:
    java -jar apktool.jar d apk.apk
    And for recompiling
    Code:
    java -jar apktool.jar b apk
    Of course I have the sdk and java installed.
  20. #20
    anthonycr's Avatar
    Posts
    Default
    Make sure now that you have C:\System32 added to your path (the resting place of the apktool).
    No I'm not getting tired of helping, I'm just getting tired.... imma fall asleep :yawn:
  21. Thread Author  Thread Author    #21
    I give up. :/
    Thanks for the help guys, but I guess I just can't do it *sniff sniff
  22. #22
    CuriousNoob's Avatar
    Banned
    Posts
    ROM
    Reflash Miui every2-3days
    Default
    What exactly are you trying to get working?
    Sent from my LG-VM670 using Tapatalk 2 Beta-5
  23. Thread Author  Thread Author    #23
    I'm trying to get mms to work on a rom I'm trying to port. I may have something though! I'm not out yet!
    I held shift, ctrl and right clicked in a folder that I extracted the apktool files, then chose "open command window here" and entered apktool and I believe it's working now!
    Gannon's guide to port: [GUIDE] How I port
  24. Thread Author  Thread Author    #24
    Quote Originally Posted by gannon5197 View Post
    Code:
    And for recompiling
    Code:
    Okay so I decompiled the framework.jar for the BASE and then got a folder called "out" inside I got "apktool.yml"
    What do I do next?
  25. #25
    Banned
    Posts
    ROM
    Default
    What do I do next?
    After decompiling, don't you replace the CDMAdispatcher or something like that from another Gingerbread rom?
