Results 1 to 6 of 6
    Default How to make 1 click anycut shortcut to navigate home?
    I saw a tutorial a while ago on how to do this but I don't remember how. You were able to make a shortcut with anycut so that all you had to do was tap the shortcut and then it would automatically load up navigation with a pre-defined address (ie home) so you could make one labled "take me home".
    Any idea on how this is done?
  2. #2
    MarkD426's Avatar
    Posts
    ROM
    Harmonia 2.06
    Default Re: How to make 1 click anycut shortcut to navigate home?
    Quote Originally Posted by colonelcack View Post
    Set a Home address on your preferred GPS application? This is a bad idea as if you phone gets lost or stolen they know where you live and if your there. All they have to do is call.
  3. #3
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    Quote Originally Posted by MarkD426 View Post
    with lookout mobile security you can quickly lock/activate alarm/locate your stolen device from any internet connented pc... :-)
    Not really too worried about losing my phone and the thief somehow knowing where i live...lol. Isn't there a way to do this with the make your own option?
  5. #5
    This seems to be "common wisdom" which doesn't hold water, on examination. What magical power has my cell phone given these thieves? How does calling my land-line give them the upper hand? My number's in the phone book, along with my name and address, and has been for 30 years. Reverse-lookup sites abound on the net. Thieves can pick any house at random and call it. They don't need a stolen cell phone to do this.
    Time to put that ridiculous canard to rest. Social sites where you "check in" to a location in real time, are far more dangerous, as they actually tell strangers that you're not at home.
    As for one-click home navigation - it appears it's no longer possible. But if you set your home address, you have 2-click navigation. When you open the Nav app, there's a Go Home button, and it does just what you expect.
  6. #6
    A-android-B's Avatar
    Posts
    ROM
    it changes so much
    What rom are you using? Ics cm9 Bobz and cold as ice have widgets you can set up just like this, actually if I remember correctly cm7 has this too I think if you hold on the home screen
    P.S. if your scared go to church this is America, get a gun
    come to the dark side
    beamed from the mothership...
    but its only a proxy for my
    lubuntu 12.04
