3G fix for Quattrimus for technicilly challenged |thanks cole2kb!
cammykool
Resident *****
Sep 5, 2011
955
74
Flash Alpha 7 or 8 of CM9. (conformed on allpha8 by drm1992)
When it's all booted, open up Play and download ES File Explorer.
Press the Menu key, go into Settings, and check 'Root Explorer' and 'Mount system as r/o writable' (or something like that).
Tap 'Favorites' and click on the little phone icon with a / under it.
Tap the 'system' folder.
Tap 'build.prop' and it will ask you what to open it in, choose ES Note Editor.
Find the line that says "#ro.telephony.ril.v3=signalstrength,skipbrokendat acall,facilitylock,datacall,icccardstatus,1"
Delete the #
Press the Menu button, tap 'Save' and reboot your phone.
Done.
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Re: 3G fix for Quattrimus for technicilly challenged |thanks cole
I only advised Alpha 7 because I thought I remembered reading people having issues with Wi-Fi and other things being broken that weren't in A7. If A8 works for you, go for it.
Glad I could be of some help. Credit for the fix goes to eletendre84. Hit the thanks button on this post: http://forums.androidcentral.com/op...rom-alpha-quattrimus-ics-269.html#post1714914
edit -- It should be noted that if you are running one of the AOKP builds that doesn't have root access, you'll need to flash those Superuser binaries first, as this requires root.
Reactions: heloworld
cammykool
Resident *****
Sep 5, 2011
955
74
if people dont beleve me ill flash ICS and do the edit tom see if it workks if it sdoesnt ill get this thread removed
Badboytoast
820
122
The 3g fix does in fact work, ive tryed it in alph 8 and yes it works!! Could you also post jerry mms fix!
arnold1997
693
117
People have accomplished getting mms to work but i have tried everything and had no luck
But in the apns-conf.xml file in etc
Look for virgin mobile usa and change
mcc=311 and mnc=490
Hope it works
Sent from my VM670 using Tapatalk 2 Beta-5
cammykool
Resident *****
Sep 5, 2011
955
74
does 3G icon turn blue lock on or just like stay grey (connected but weak or unsecure)
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
From my usage of CM9, it is SUPPOSED to turn blue, it's a bug in our ROM, sometimes it will and sometimes it won't. Rest assured, after applying this fix, you have 3G. Icon or not. :)
cammykool
Resident *****
Sep 5, 2011
955
74
yeah my buddy has a droid X with ics and it wors so well 3G icon goes blue too
cammykool
Resident *****
Sep 5, 2011
955
74
Sent from my LG-VM670 using Tapatalk 2 Beta-5
heloworld
47
How do you flash the Superuser binaries?:)
kevinrshay1984
