lg optimus v battery comsumption
miguel760
12
ive been wondering if all lg optimus v from virgin mobile waste a lot of battery? i got a brand new phone and ive tried battery saving apps and they dont work as much, my battery drains quick with in a few hours, its nothing compared to my ipod :/ i dont know much about androids but there seems to be a problem with this phone's battery or the phone doesnt work.
Sean OGorman
69
6
Battery saving apps are a bandaid at best. You need to find out what specific app(s) are sucking the life out of the battery with constant syncing, checking location (banner ads on free apps), etc. Also, the frequency of use has a huge effect. Sitting idle, an Optimus V should only lose 1-2% per hour, but with heavy use you can kill the battery in just a few hours.
Reactions: miguel760
miguel760
12
which battery apps are the best because theres a bunch of them on the market, i got juice defender, advanced task killer, battery booster and plus a few games that i dont use often and still my battery decreases by one percent every 2 minutes. my friend has an optimus v with the same provider and everything and at the end of school we compare our phones and mines like 40% lower than his, i dont get it?
EarthnFire78
YAY!!! ME :)
Jan 1, 2012
964
232
Most battery saving apps and any task-killer apps are a waste of time. Android is setup for multitasking unlike the iPod or even the iPad/iPhone, so apps that sync always run in the back-ground.
Not saying that the V battery life is bad with the right setting and knowing what apps doe what I get 18 - 21 hours on a single charge.
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
You don't have all those apps going at once, do you? Some of them probably run in the background without you knowing.
I get the impression you're running the stock software. There are apps pre-loaded on your phone that will drain the battery. Also, apps that use background data that you install like Facebook, Twitter, Foursquare, GMail, etc... will eat your battery. My advice would be to remove all the apps you've installed, add a Power Widget to your homescreen and make sure to disable 3G, GPS, and/or Wi-Fi when you're not using it, lowering brightness when appropriate, etc... Of course, I want to tell you to root, install a custom recovery, and load Harmonia 2 on there, but...well, one step at a time. :)
CuriousNoob
Banned
Aug 2, 2011
1,590
202
I'm sorry... But I remember Leslieann saying it was proven that Task Killers DO help if your on a stock rom.
arnold1997
693
117
so its good to have task killlers in a "stock rom" idk what that is but ok?
Stock rom is the rom thebphone comes with out of the box. Rooting and custom rom do expand battery life by the hours...but like previously said one step at a time
Sent from my VM670 using Tapatalk 2 Beta-5
Ph1Man
Active member
Mar 26, 2011
36
9
Here is the best guide to better battery life on the v. Even on stock rom like yours it will double the life.
https://github.com/inferiorhumanorg...e_thunderc_common/wiki/Improving-battery-life
But you really should look into rooting and flashing a better rom you will get 4x the battery life.
Here is the info on how to do it. But Google rooting and roms first.
http://forums.androidcentral.com/op...-how-simplified-root-recovery-custom-rom.html
If you choose to root and want the best battery life go with Haromina 2 and not the one recommended in the post above. It can be found here: http://forums.androidcentral.com/op...2-iho-gingerbread-see-first-post-updates.html
Edit: PS: here is a good starting point to help understand what rooting and roms are.
http://www.droidxforums.com/forum/d.../36289-dummies-like-me-rooting-roms-more.html
droidmyme
824
64
No, the king of battery life ROMs is Harmonia 1.8
http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/78956-rom-harmonia-1-6-1c-aphrodite-picasticks-21sept11.html
droidmyme
824
64
I didn't know that it was better than H2. I know what my next rom will be. Thanks for the info.
For Dummies like me - rooting, ROMs, and more
Harmonia 1.x is built on Android 2.2 (Froyo). Its simple, but battery life is very good. Harmonia 2.x is built on 2.3, Gingerbread, on the other hand. GB has additional features but uses more battery.
Speaking from experience, when I switched from CyanogenMod7 (Gingerbread) to Harmonia 1.8, I got 1-2 more hours of use per charge. I love CM but the long battery is what made me go back to Harmonia haha :)
Reactions: Ph1Man
EarthnFire78
YAY!!! ME :)
Jan 1, 2012
964
232
Task-killer are fine to a point on stock ROMS, but if all it is doing is killing a bunch of task set by apps that run in the background then it waste more battery then it well save. The best thing is to use the menu button for each app that sync's data and adjust how offend the app sync's,and the ones that you cannot change/adjust uninstall.
khalio1234
