1. braxton355's Avatar
    Can anyone direct me to a download for bobz kernel for the OV?
    05-05-2012 06:53 PM
  2. Discovered's Avatar
    solved
    05-05-2012 06:54 PM
  3. curtis1973's Avatar
    [QUOTE=braxton355;1761218]Can anyone direct me to a download for bobz kernel for the OV?[/QUOTE)
    original thread : http://forums.androidcentral.com/showthread.php?p=1760821
    download:
    http://www.mediafire.com/?rdgdxf0hxnsvyr1
    braxton355 likes this.
    05-05-2012 06:55 PM
  4. braxton355's Avatar
    Thank you, and do you know where I can download a recovery? I have CWM and I'm trying to install the ZM9 security update!
    05-05-2012 09:25 PM
  5. sellers86's Avatar
    Don't install it. It causes nothing but problems
    05-05-2012 09:41 PM
  6. rebel69ization's Avatar
    05-05-2012 10:19 PM
  7. curtis1973's Avatar
    im using the kernel now on iho. no issues at all.
    EDIT: READ CURTIS READ!! ...no dont install the radio update...pure garbage from vm imo...as for bobzhome kernel,with or without the radio update,its a good thing to have imo.
    05-05-2012 10:36 PM
  8. braxton355's Avatar
    So is it not worth flashing the update? I read that it helps reception. Is that true?
    05-06-2012 12:05 AM
  9. demoport's Avatar
    Nope. For a lot of people, it had no real provable improvement and in fact ruined their phone with stability problems, random reboots, and unreliable texting. Avoid at all costs, I wish I never updated :\
    05-06-2012 01:05 AM
  10. thewraith420's Avatar
    The rebooting while testing/calling issue has seems to be solved and it has helped at least some people's signals. I did it and only had a few reboots even with the old kernels.
    Edit: Also I posted a link on the radio update thread for the stock zv9 recovery its what I use when I need to flash the zv9 update.
    05-06-2012 01:32 AM
  11. braxton355's Avatar
    I'm just not gonna do it. Maybe in the far future! But I'm gonna take the communities advice for right now. Thanks guys!
    05-06-2012 03:04 AM
