Results 1 to 13 of 13
    skinneysk8's Avatar
    Posts
    ROM
    Harmonia 2.06
    Default Recovery Help!!
    I've installed Flash Image GUI and flashed the VM670 Recoverery image, however, when I power the phone off to go into Recovery, I get a black screen. Any suggestions?
  2. #2
    Default
    try flashing it again....same thing happened with me I just flashed it again and it worked.
  3. #3
    kwknott's Avatar
    Posts
    ROM
    Backside... MiRaGe
    Default Re: Recovery Help!!
    Yeah sounds like a bad flash. If you downloaded the one from the sticky there shouldn't be any issues with block screen. To be safe I'd redownload it to make sure you didn't get a bad download and try flashing again.
    Just in case you need it use the one from this thread under "Install Custom Recovery Image"
    [HOW-TO] Simplified Root + Recovery + Custom ROM
    skinneysk8's Avatar
    Posts
    ROM
    Harmonia 2.06
    Thanks for the replies. I've flashed the recovery image 6 x, to no avail. I've even uninstalled the Flash Image GUI, reinstalled it, and flashed the Recovery Image again, to no avail. Could it possibly be due to the update from Virgin Mobile or....?
  5. #5
    cmerlyn's Avatar
    Posts
    ROM
    Godzilla
    Default
    Probably not, I had no difficulty flashing that recovery from flash GUI, and I have the VM upgrade.
    I trust you have verified the md5 on the recovery from your phone. I have had many files go bad while copying from my PC to my phone. I now check it after copying as well as before.
    Thanked by:
  6. #6
    EarthnFire78's Avatar
    YAY!!! ME :)
    Posts
    ROM
    Custom ROM & Kernel
    Another things, Flash_Image GUI as a problem fully flashing a recovery if the image is not named recovery.img.
    skinneysk8's Avatar
    Posts
    ROM
    Harmonia 2.06
    I haven't checked the md5 sum. I've re-downloaded the .img file and attempted to flash again, to no avail. So, I've attempted to flash recovery by utilizing Terminal Emulator (per LeslieAnn's posts), however, I'm getting the 'file not found' msg when doing it this way. Any suggestions?
  8. #8
    curtis1973's Avatar
    King Of Pants
    Posts
    ROM
    CM10/Sense
    Default
    probably isnt the issue,but be sure you mark recovery image and not kernel when flashing in flash image.
    skinneysk8's Avatar
    Posts
    ROM
    Harmonia 2.06
    Ok, so I've tried using Terminal Emulator to flash recovery, however, I get the "file not found" error msg when typing the following:
    su
    flash_image recovery /sdcard/a.img
    I'm just tryin' to get this phone to recovery mode so I can flash a ROM. Help!!
  10. #10
    Nate456's Avatar
    Posts
    ROM
    Stock, CM10, AOKP
    Default
    Try this if the recovery is in the download file
    su
    flash_image recovery /sdcard/download/a.img
    Sent from my Galaxy Nexus (not really) using Tapatalk 2
  11. #11
    A-android-B's Avatar
    Posts
    ROM
    it changes so much
    Default
    What is the name of your file? I doubt it is a.img as your posts suggest. try renaming the file to recovery.img and then use recovery.img when flashing
    beamed from the mothership...
    but its only a proxy for my
    lubuntu 12.04
    Thanked by:
  12. #12
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Default
    Incompatible recovery with new screen. Can't believe no one has suggested that. See Leslie's reference guide sticky
    Guess whos coming back!
  13. Thread Author  Thread Author    #13
    skinneysk8's Avatar
    Posts
    ROM
    Harmonia 2.06
    I was finally successful in flashing a recovery partition using Flash Image GUI, by renaming the recovery file to recovery.img. Running Harmonia 2.06, however, LeslieAnn put out the update to Harmonia 2.07, in which I will be flashing soon. Thanks for the help.
